shiggins Posted September 26, 2005 Share Posted September 26, 2005 The E/T function on my trip computer seems to have gone out. I don't check it much, as the mileage functions are much more addicting. I know it worked when I took delivery of the car 2 weeks ago, this weekend I noticed it just had the "---" no matter what I did. Is there something I did to disable it (I looked through the manual briefly and found nothing)? Or is it my first warranty repair? Link to comment Share on other sites More sharing options...
forestir Posted September 26, 2005 Share Posted September 26, 2005 Mine only shows --- when I want instantaneous mpg and I'm not moving. Next click shows avg mpg, and so on. So maybe you've selected instant mpg instead of E/T? I never use E/T. Link to comment Share on other sites More sharing options...
shiggins Posted September 27, 2005 Author Share Posted September 27, 2005 Nope, I'm definitely on the E/T screen. Everything else on the trip computer works fine, just the E/T timer does not function. Obviously I have a problem, as no one has replied with "read the manual you idiot, just press so and so and it'll reset." Damn, two weeks in and my first warranty repair. Otherwise the car seems solid. I'm hoping this is the only problem. Link to comment Share on other sites More sharing options...
mwiener2 Posted September 27, 2005 Share Posted September 27, 2005 are you really low on gas. it'll go down to about 20 miles left, then go -- My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Mr. T Posted September 27, 2005 Share Posted September 27, 2005 are you really low on gas. it'll go down to about 20 miles left, then go -- I think he means E/T as in Elapsed Time...not DTE (Distance to Empty or Range). I'm very familar with this function as I time myself on the way to work to see if I can improve on my previous best. Makes the commute more of a challenge. My E/T showed -- once but it seemed to be a one time thing and hasn't happened since.. Link to comment Share on other sites More sharing options...
Scotty Posted September 27, 2005 Share Posted September 27, 2005 Can we assume the engine is on and you are driving the car? Link to comment Share on other sites More sharing options...
Mr. T Posted September 27, 2005 Share Posted September 27, 2005 Can we assume the engine is on and you are driving the car? No, no, it couldn't be that.....could it? Please, that would be just too easy... Link to comment Share on other sites More sharing options...
mwiener2 Posted September 27, 2005 Share Posted September 27, 2005 o well in that case..... did you try kicking it? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
emorphien Posted September 27, 2005 Share Posted September 27, 2005 Never heard of that one before. Maybe you should stop squinting at the display. Link to comment Share on other sites More sharing options...
shiggins Posted September 27, 2005 Author Share Posted September 27, 2005 Ha! Time warp it is. I kept wondering why I'd leave for work on Tuesday and get there and it seemed like it was only Monday..... No, I went through all the obvious things, and yes the car is on and I am driving it. It's a simple problem of the elapsed time not functioning right now as it should. I'll just have the dealer take a look at it. It's a small issue, but still sucks 'cause I really don't want some mechanic taking things apart to replace them. The car is still in it's virginal state, no good comes from taking things in the dash apart. I had just hoped I had done something stupid (like when I spent 15 minutes last week trying to figure why my parking lights wouldn't go off before I remembered faintly some post about a switch on top of the steering column ) and it would be an easy fix. Well, at least it's the only problem so far, and it's minor. The rest of the car is rock solid. Link to comment Share on other sites More sharing options...
forestir Posted September 27, 2005 Share Posted September 27, 2005 Is the clock running? Perhaps you've tried to set the time of day recently and that messed it up? I guess we're running out of valid suggestions now... but I figure the E/T is tied to the clock, so that might be a clue. Link to comment Share on other sites More sharing options...
mwiener2 Posted September 27, 2005 Share Posted September 27, 2005 clock is completly seperate My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
shiggins Posted September 27, 2005 Author Share Posted September 27, 2005 Well, to top it off, when I left for a meeting today, it started working. Of course when I left after the meeting it was not working again. So it's definitely an issue I'll address with the dealer at the first oil change. I already mentioned it to the sales guy when he called to tell me my plates were in. The Elapsed Time is tied into the ignition and resets then starts each time you turn the key on, so somewhere in that path, it seems there's a problem, as the E/T doesn't start counting. Link to comment Share on other sites More sharing options...
phoenix96 Posted November 1, 2005 Share Posted November 1, 2005 My car's E/T timer started displaying "---" recently also. Only ~400 miles on the odometer. I'd be interested in hearing if you found out anything about the problem. phoenix96 2006 Legacy GT Ltd · 2011 Outback 3.6R Ltd · 1992 SVX 2006 Outback 3.0R VDC · 2009 Forester 2.5X 2002 Outback VDC · 1996 Outback 2.5L · 1986 GL-10 Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted November 1, 2005 Share Posted November 1, 2005 It's bwoken. Link to comment Share on other sites More sharing options...
pellerin Posted November 1, 2005 Share Posted November 1, 2005 Perhaps you could try a hard reset by unhooking the battery cables for 15 minutes. I imagine it would clear your trips and other memory items, but it might fix your E/T issue. Best of luck - Kent ('05 GT Wagon, 3500mi) Link to comment Share on other sites More sharing options...
fweasel Posted November 1, 2005 Share Posted November 1, 2005 My 06 is less than a week old, ~250 on the odometer and the E/T also shows --. Can't say I ever use the feature, then again, its only been 6 days. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
shiggins Posted November 1, 2005 Author Share Posted November 1, 2005 I haven't solved it yet. It works on rare occasion, but mostly nothing, just the ----. I'm waiting to take it into the dealer one of these days. It's such a minor problem that I don't want to give up my car during these last nice days here before snow. Link to comment Share on other sites More sharing options...
phoenix96 Posted November 1, 2005 Share Posted November 1, 2005 I haven't solved it yet. It works on rare occasion, but mostly nothing, just the ----. I'm waiting to take it into the dealer one of these days. It's such a minor problem that I don't want to give up my car during these last nice days here before snow. While I'm not sure what this 'snow' is that you speak of, I am also waiting to take my car to the dealer (a 90 minute drive). The journey time is such a minor issue that it can wait until the car's first oil change. phoenix96 2006 Legacy GT Ltd · 2011 Outback 3.6R Ltd · 1992 SVX 2006 Outback 3.0R VDC · 2009 Forester 2.5X 2002 Outback VDC · 1996 Outback 2.5L · 1986 GL-10 Link to comment Share on other sites More sharing options...
shiggins Posted November 1, 2005 Author Share Posted November 1, 2005 Ohhhhh you people and your bright sunshiny days all year round. I hope you get sunburned in January......while I'm out shoveling 12" of snow in 15 degree weather. Link to comment Share on other sites More sharing options...
SWP-LegacyGT Posted November 2, 2005 Share Posted November 2, 2005 Unplug the battery, plug it back and it should show up again. Full system cycle. Link to comment Share on other sites More sharing options...
phoenix96 Posted November 6, 2005 Share Posted November 6, 2005 I found today that the journey time indicator works fine if I turn the ignition to On just long enough for the "---" to show up before starting the car. Turning the key from Lock to Start directly apparently doesn't give the trip computer enough time to boot up, and when it does after the car is already running it doesn't begin counting as it should. phoenix96 2006 Legacy GT Ltd · 2011 Outback 3.6R Ltd · 1992 SVX 2006 Outback 3.0R VDC · 2009 Forester 2.5X 2002 Outback VDC · 1996 Outback 2.5L · 1986 GL-10 Link to comment Share on other sites More sharing options...
fweasel Posted November 8, 2005 Share Posted November 8, 2005 I found today that the journey time indicator works fine if I turn the ignition to On just long enough for the "---" to show up before starting the car. Turning the key from Lock to Start directly apparently doesn't give the trip computer enough time to boot up, and when it does after the car is already running it doesn't begin counting as it should. This is the same scenario on my '06 as well. I tried it out last night with identical results. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
emorphien Posted November 8, 2005 Share Posted November 8, 2005 Strange problem. Haven't seen it, then again I never use the E/T thing either. Link to comment Share on other sites More sharing options...
TSiWRX Posted November 8, 2005 Share Posted November 8, 2005 Hum.... I typically like to keep an eye on ambient temps, so I never leave the computer on the E/T mode - I've *never* gotten the "---" before, and perhaps this (i.e. my practice) is why? I cycle-through to the E/T both in the early AM as well as in the evening, when I'm about to start my commute, so I can make myself sit-still while warming up the vehicle. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
