mkee87 Posted August 31, 2015 Share Posted August 31, 2015 Engine was bucking pulling up to stop light so I pulled a quick log. Any ideas of the culprit?datalog2.csv Link to comment Share on other sites More sharing options...
MTBwrench Posted September 1, 2015 Share Posted September 1, 2015 I notice two things: 1) You have negative A/F learning when the engine is under full vacuum. That's definitely not normal... As that would mean the ECU is seeming less air coming out of the exhaust that what's being pulled in. That's not really possible under vacuum unless you've got a leaky injector or bad MAF, causing things to run rich. The AF ratio looks decent though. If you're getting close to, or have more than, 100,000 miles you may want to replace the front O2 sensor. Log A/F learning a,b,c,d and post it up. That'll give more info as to what's going on. Also, are you on the stock tune? Any mods? 2) At times the OCV's are almost 4° apart, that's not good either. I've never seen mine vary more than about 1°. This can cause all kinds of drivability issues as cylinders 1&3 will be seeing a different running condition than cylinders 2&4. Take a short cruise log and look to see how they behave. I don't know much about this stuff, but that would be my plan of action. MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
mkee87 Posted September 1, 2015 Author Share Posted September 1, 2015 I was thinking it was a sticky fuel injector myself. The ocv I already know about and have a new one on order. I'll log the full a/f learning values on my way to work tonight and post them in the morning. Link to comment Share on other sites More sharing options...
mkee87 Posted September 1, 2015 Author Share Posted September 1, 2015 Here's more logs with full a/f learningparking lot.csvfreeway cruise.csvidle after drive.csv Link to comment Share on other sites More sharing options...
MTBwrench Posted September 1, 2015 Share Posted September 1, 2015 Hmmm, its really pulling a ton of fuel. All the ranges(A,B,C,D) are in the negative, which technically shouldn't be possible. Just for reference, heres a little description of them: A/F Learning 1A: Idle A/F Learning 1B: A very small range between idle and cruise... I rarely log it unless told to. A/F Learning 1C: Cruising speeds (i.e.- doing 45mph under vacuum) A/F Learning 1D: Pretty much all WOT/lots of boost operation How does it run? I assume not very healthy? With that much fuel being pulled something is definitely up. From what I've learned/read/expereinced theres a few possibilities: 1- A bad front O2 sensor. They go bad all the time without throwing codes, and at your mileage it's very possible. 2- Fueling issue such as sticky injector. This can be serious as the ECU will pull fuel to compensate for the overly rich cylinder and make the others run much too lean. That leads to cracked ringlands, burnt valves... Are your fuel injectors making any weird noises as of late? 3- A bad MAF. This means the ECU is being told the engine is sucking in a different amount of air than it actually is. It can lead to all kinds of driveability problems. Pull out your MAF and clean it with some CRC Mass Airflow cleaner aerosol. And, saving the worse for last... 4- A cracked ringland or burnt valve can cause incomplete combustion and blow un-burned fuel through the exhaust. The ECU reads it as running rich and pulls fuel to compensate. I would honestly go to Autozone or something and rent a compression tester. It'll give you a good idea as to how healthy your engine is anyways! MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
mkee87 Posted September 5, 2015 Author Share Posted September 5, 2015 I replaced my front O2 sensor 2 weeks ago, and my MAf less than a year ago. I put in a set of new(refurb) injectors today and so far they seem to be doing the trick. I did a long data log and my fueling trims are back within spec across the board with trim A still being a tad high.datalog13.1.csv Link to comment Share on other sites More sharing options...
MTBwrench Posted September 5, 2015 Share Posted September 5, 2015 Looks much better! However the negative correction in the A range still seems odd to me. I would drive it for say 100 miles (gently) and see how everything settles in. Did you reset the ECU when you installed the new injectors? MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
fahr_side Posted September 5, 2015 Share Posted September 5, 2015 Hmmm, its really pulling a ton of fuel. All the ranges(A,B,C,D) are in the negative, which technically shouldn't be possible. Just for reference, heres a little description of them: A/F Learning 1A: Idle A/F Learning 1B: A very small range between idle and cruise... I rarely log it unless told to. A/F Learning 1C: Cruising speeds (i.e.- doing 45mph under vacuum) A/F Learning 1D: Pretty much all WOT/lots of boost operation Not quite. Negative fuel trims, like down to -5 or so, are quite normal with the stock hardware and MAF scaling. This just means the stock MAF is set a little high, which causes the injectors to spray just a little more fuel than is needed to hit stoich, and the AF correction and long-term trims to pull a little fuel to fix that. OEM thinking is that it's a little better to start slightly rich and then pull fuel to fix that. AF Learning range D in most ROMs covers an AF range from 50g/s up to the switch to open loop. All operation at WOT or under boost should be in open loop, which does not come under the scrutiny of the closed loop correction system at all. Learning range D is usually only reached in fast highway cruising or slightly slower cruising uphill where throttle angle and rpm do not quite kick the ECU into open loop operation. Correction learned in range D are however applied to injector pulse width in open loop operation, so large trim values here are still undesirable. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
MTBwrench Posted September 6, 2015 Share Posted September 6, 2015 Mkee87, listen to this guy!^ As you can see, he knows A LOT more than me, so he's probably a better source for advice. Sent from my iPhone using Tapatalk MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
fahr_side Posted September 6, 2015 Share Posted September 6, 2015 I would drive it for say 100 miles (gently) and see how everything settles in. Did you reset the ECU when you installed the new injectors? This is also what I'd do. No need to reset, the trims will shift to a stable range pretty soon. Sent from some electronic device. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
mkee87 Posted September 6, 2015 Author Share Posted September 6, 2015 I did reset my ecu after installing the injectors. I'll check again in 100 miles and see how everything is looking. Link to comment Share on other sites More sharing options...
