jkp Posted July 25, 2015 Share Posted July 25, 2015 My recently acquired old car, 2005 Outback 3.0 R, is soon in need of an oil change. 159,600 miles. Runs real well. First oil change I used Max Life 5/30. Now , 3000 miles later, Max Life again, or a good synthetic 5/30 ? I generally feel more confident with syn, but Max Life has good marketing. Any 3.0 suggestions ? Thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted July 25, 2015 Share Posted July 25, 2015 Your fine for most cars oil is oil, keep doing what your doing. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MTBwrench Posted July 26, 2015 Share Posted July 26, 2015 I've run Max Life in my 5.7 Tahoe for the last 22,000 miles, currently has 174k on it. A shady mechanic told me a few years ago that my cam bearings were going and I needed a new engine(obviously a lie), that's when I started using high zinc oils. Still comes out coal black every time, but my dad maintains that truck with rather crappy OCI's, and it's still kickin'! But like Max said, in the end oil is oil, especially for an N/A motor. The H6 isn't anywhere near as hard on oil as the GT's and XT's are, so you can just ignore all the oil brand banter on here from those guys MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
whitrzac Posted July 26, 2015 Share Posted July 26, 2015 Just run rottella t6 in everything. It's cheap, has an amazing detergent package, and has a high zinc content. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 27, 2015 Share Posted July 27, 2015 As I've said before, my 05 spent the first 154,000 miles on cheap 5w-30 and Fram filters. The turbo lasted 142,000 miles. Not bad when you read all the turbo failures at less mileage and using better oil. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
