Charliet1 Posted June 25, 2015 Share Posted June 25, 2015 Hi All, I need a little help... as I was recharging the ac this morning, and the engine was running I noticed steam coming out of a small hole in the front of the radiator. I continued to charge the ac and naturally the volume of steam increased. The engine temperate on the dash however stayed normal. Should I get the radiator changed..?? or just leave as is and avoid traffic jams...?? Link to comment Share on other sites More sharing options...
Nightmaresmk Posted June 25, 2015 Share Posted June 25, 2015 Yes. little leaks will get worse. Link to comment Share on other sites More sharing options...
compsurge Posted June 25, 2015 Share Posted June 25, 2015 From the sound of it you should also get your A/C worked on. There should be zero need to add refrigerant in a properly working system. Radiators can be done yourself for under $100. Look for a replacement radiator on Amazon. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted June 25, 2015 Share Posted June 25, 2015 You will want to have you ac system maintenanced every couple of years though to refresh oil and such. Link to comment Share on other sites More sharing options...
Charliet1 Posted June 25, 2015 Author Share Posted June 25, 2015 I thought so, unfortunately I don't have a garage, living in Brooklyn otherwise I'd do this one myself. The beast is 10 years old, I had the time belt done about 2 months ago. So an AC overhaul probably isn't out of the question, adding the refrigerant worked tho she blows cold again. Thanks guys Link to comment Share on other sites More sharing options...
boxkita Posted June 26, 2015 Share Posted June 26, 2015 move general ? to general forum Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
b16z6s20 Posted July 4, 2015 Share Posted July 4, 2015 anyone knows if the radiator for the 5eat turbo legacy will work on the 4eat limited sedan? thanks. Link to comment Share on other sites More sharing options...
Kevin622 Posted July 4, 2015 Share Posted July 4, 2015 Are you sure it isn't your ac condenser it sits right in front of your radiator? Link to comment Share on other sites More sharing options...
compsurge Posted July 4, 2015 Share Posted July 4, 2015 anyone knows if the radiator for the 5eat turbo legacy will work on the 4eat limited sedan? thanks. http://opposedforces.com/parts/legacy/us_b13/ Link to comment Share on other sites More sharing options...
Phillip J. Fry Posted July 4, 2015 Share Posted July 4, 2015 Hi All, I need a little help... as I was recharging the ac this morning, and the engine was running I noticed steam coming out of a small hole in the front of the radiator. I continued to charge the ac and naturally the volume of steam increased. The engine temperate on the dash however stayed normal. Should I get the radiator changed..?? or just leave as is and avoid traffic jams...?? change it man. be lucky you found the leak when its small and you can get around. change it as soon as you can. Link to comment Share on other sites More sharing options...
Flinkly Posted July 5, 2015 Share Posted July 5, 2015 Are you sure it isn't your ac condenser it sits right in front of your radiator? I was thinking the same thing. Is it the engine radiator or the A/C "radiator"? I'm thinking high chance that it's number two. Sent from my XT1028 * Build Thread * 26.53 MPG - 12 month Average * Link to comment Share on other sites More sharing options...
compsurge Posted July 5, 2015 Share Posted July 5, 2015 I'm also inclined to link the low refrigerant and leaking condensor. Check the site I linked to verify the part you are wanting to replace is the correct part. Link to comment Share on other sites More sharing options...
