swegowego Posted May 28, 2015 Share Posted May 28, 2015 Hi, I'm having problems with my car again. After a couple months of struggle trying to figure out why it was overheating. So I decided to pull the engine out and do the gasket and I marked everthing so I didtn loose track of where everything goes, but now that everything is back together the car is cranking and not starting. The fuel pump work for sure I tried it and before the car was running good just overheating. So don't know what to do now anybody had that problem previously ??? I had the car for a year and did 2000km on it and im getting close to bringing it the the dump. Link to comment Share on other sites More sharing options...
NVAKeith Posted May 29, 2015 Share Posted May 29, 2015 Timing belt off a tooth or two? Got spark? Checked fuel pressure? Link to comment Share on other sites More sharing options...
swegowego Posted May 29, 2015 Author Share Posted May 29, 2015 Did you ever try to get to the spark plug from underneath? And how difficult is it ? Link to comment Share on other sites More sharing options...
Max Capacity Posted June 1, 2015 Share Posted June 1, 2015 You should ask this question in the 4th Gen forum, you'll get more help there. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
