rodan Posted September 20, 2005 Share Posted September 20, 2005 After some searching and lots of reading, I have not found the answer to the following question: If you are running a standard AP map (say from a ProTuner shop), can you use Street Tuner to datalog? As I understand it, the answer would be no, as (according to the user guide) the ST requires you to flash a ST base map in the marrying process. Is this correct? I would very much like to get ST, as it's a fantastic tool, and looks like it would meet my future needs, but I would also like to do some datalogging and optimizing on my current configuration. It looks like ST is incapable of this? Anyone using ST on their Legacy? Link to comment Share on other sites More sharing options...
rao Posted September 20, 2005 Share Posted September 20, 2005 After some searching and lots of reading, I have not found the answer to the following question: If you are running a standard AP map (say from a ProTuner shop), can you use Street Tuner to datalog? As I understand it, the answer would be no, as (according to the user guide) the ST requires you to flash a ST base map in the marrying process. Is this correct? I would very much like to get ST, as it's a fantastic tool, and looks like it would meet my future needs, but I would also like to do some datalogging and optimizing on my current configuration. It looks like ST is incapable of this? Anyone using ST on their Legacy? Nope, the AccessPort can no l onger use standard AP maps once you convert to ST. Cobb provides very similar maps to the AP maps to be used as a start in ST. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
rodan Posted September 20, 2005 Author Share Posted September 20, 2005 Thanks for the quick reply! I was thinking that would be the case. In my situation, I am getting an map from a ProTuner, which should be pretty close for me (closer than the Cobb OTS ST map), but still may need some tweaking due to altitude, etc. I was hoping to be able to log that, and build the ST map from what I find there... I'm looking into the TARI software as a possible solution to log the AP map. Link to comment Share on other sites More sharing options...
SpeedNeeder Posted December 7, 2005 Share Posted December 7, 2005 Is there a tuning for dummies post on here somewhere? I think that dabbling in street tuner would be really fun, but I don't know anything about tuning. My other car is a 1993 Chevy S-10 Tahoe! (Currently being driven to failure by my nephew) Link to comment Share on other sites More sharing options...
