OhNineGT Posted May 14, 2015 Share Posted May 14, 2015 Well if you guys didnt see my last post. I bought a 09 LGT last monday. Since then, I have had to replace the turbo, oil, coolant, spark plugs, and air filter. All of which hadn't been done in what looked like, quite a while (Probably why the turbo went bad). I'm trying to explore all my options here. Keep in mind Lemon Laws dont cover used cars in Utah. I was told by Subaru that it was just a turbo and that that would fix my problems. I changed the turbo AND the plugs. My check engine light is still on and is pulling codes of P0301, P0303, and P0304 (Misfiring). I'm going to get everything checked out tomorrow (Hoping for coils) to see if it is something that is fixable. My question to you guys. I'm trying to figure out if it is going to be more cost effective to get a lawyer or a new block for this. What does a new block run for these cars? I have read $1900 but I could have read out of context? Thanks in advance for your help! Link to comment Share on other sites More sharing options...
Disgust Posted May 14, 2015 Share Posted May 14, 2015 Hey man, I've been in your shoes many times before. What I can tell you that's a good thing is that you have a misfire on cyl #1 which normally points to something stupidly easy, but then again if your car wasn't maintained, it could be a bad HG. From my experience with the codes: Cyl #4 is a bad one to get a misfire on and normally points to burt valve or maybe even a crapped head gasket. HOWEVER, multiple cyl misfires, especially after changing sparks, is a good thing. This normally means that you forgot to do something like add dielectric in the terminals or somehow your spark gap is super out of whack. I had a misfire on cyl #4 a couple months bad and I was turding bricks for a bit. Then, when I was about to get ready to remove the engine for a rebuild, I found that I had forgotten to connect the ignitor on cyl #4. Just take your time and look over everything again if you did it yourself, or take it back to the shop that did your sparks and ask them to take a look. Have fun with the car, these things are amazing when they actually work lol Link to comment Share on other sites More sharing options...
Mike07LGT Posted May 14, 2015 Share Posted May 14, 2015 Sounds like you need a new Shortblock $1645 I believe for a new shortblock from heuberger 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
Max Capacity Posted May 15, 2015 Share Posted May 15, 2015 Make sure the connectors are tight on the coils. Common issue. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
OhNineGT Posted May 18, 2015 Author Share Posted May 18, 2015 Gave up. Getting it rebuilt on Thursday. $2000 rebuild with upgraded heads and timing belt. Also he is upgrading the clutch to a stage 3. 2 year unlimited mile warranty. Not bad. Link to comment Share on other sites More sharing options...
700watts Posted May 18, 2015 Share Posted May 18, 2015 Looks like you made your mind up, but it's hard for me to believe there's no consumer protection for buying a used car in Utah only nine days old. Was this a private sale? One would tend to believe it wasn't since you mentioned lemon laws. Link to comment Share on other sites More sharing options...
OhNineGT Posted May 19, 2015 Author Share Posted May 19, 2015 @700watts if you can find any kind of a loop hole that I haven't seen.. I more than welcome you to inform me. Link to comment Share on other sites More sharing options...
Merc6 Posted May 19, 2015 Share Posted May 19, 2015 That sucks, at least you are in the right place to get the answers you need. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
