boxkita Posted May 15, 2015 Share Posted May 15, 2015 all it has to do is keep the heat from radiating into the cv axle space. If you were motivated, you might be able to use the 2 inch thermal wrap and do it on the car. I did mine off the car and it took 2 ppl to get the wrap tight enough. And a 3rd to take compromising pictures. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
ivonr Posted May 16, 2015 Author Share Posted May 16, 2015 I think my best bet is just to have the DP removed and wrapped Link to comment Share on other sites More sharing options...
shortfusemonkey Posted May 18, 2015 Share Posted May 18, 2015 so, after reading this. I am still not sure. i plan to wrap the downpipe, but should I or shouldn't I wrap the cat on it? Link to comment Share on other sites More sharing options...
Akasa Posted May 19, 2015 Share Posted May 19, 2015 Personally, I would not wrap the catalyst. It's true that catalysts work best when they're hot, but they get plenty hot from driving alone. Too much heat has the potential of breaking the converter up over time. In the long term, wrapping your exhaust shortens it's lifespan. Do some more research across other forums and make an informed decision based upon all of your sources. There is no one source of truth on the internet. Link to comment Share on other sites More sharing options...
I Donated Too luchadorjose Posted May 19, 2015 I Donated Too Share Posted May 19, 2015 Ceramic coating cost me 75$, it works just as well if not better than wrapping, and looks way better. Just saying Link to comment Share on other sites More sharing options...
boxkita Posted May 19, 2015 Share Posted May 19, 2015 I think my best bet is just to have the DP removed and wrapped Get a friend to help you, as its much easier. Also get the stainless tie wraps. Keep in mind which way air flows over the DP...so start wrapping from the exhaust end, not turbo end. The Titanium DEI wrap is more expensive, however, you don't have to soak it first. The helper holds the DP while you pull the wrap very tight. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
ivonr Posted May 20, 2015 Author Share Posted May 20, 2015 I'm having a shop replace my up pipe so while they're at it they will wrap the downpipe too. Problem solved...I hope Link to comment Share on other sites More sharing options...
ivonr Posted May 28, 2015 Author Share Posted May 28, 2015 they wrapped the catted portion, since it is close to things that can be damaged from radiating heat. shop said the cats should be rated for 800 degrees or so, which is how much heat would be generated and kept in by the wrap. i have a CNT catted 5EAT downpipe, hope he cat holds up... Link to comment Share on other sites More sharing options...
baci Posted May 29, 2015 Share Posted May 29, 2015 I suspect the CV boot gets torn more so from the down pipe removal and not so much from the heat. I have never seen the boot melted. Granted the extra heat probably doesnt help the lifespan of rubber. But hitting the DP on the CV boot will surely do more damage than anything. Ive had my DP wrapped for 2 years now and the CAT is still fine. Im more worried about corrosion than the cat degrading. Link to comment Share on other sites More sharing options...
ivonr Posted May 29, 2015 Author Share Posted May 29, 2015 i also had my stock uppipe replaced with a grimmspeed heat-coated flex unit. nice piece of pipe (lol) but i am concerned the heat radiating from that will cause issues too. shop said they didn't want to wrap that because it can be a fire hazard in the event of a fluid leak. is the heat coating from grimmspeed enough? Link to comment Share on other sites More sharing options...
I Donated Too luchadorjose Posted June 1, 2015 I Donated Too Share Posted June 1, 2015 thermal coating > exhaust wrap Link to comment Share on other sites More sharing options...
ivonr Posted June 8, 2015 Author Share Posted June 8, 2015 sounds good, i will leave it be then Link to comment Share on other sites More sharing options...
