subarunewb Posted May 9, 2015 Share Posted May 9, 2015 I'm trying to figure out how to change the speakers in my two front doors. Anybody know anywhere I can get instructions on how to do this? I'm looked on Google over and over. No luck yet. Link to comment Share on other sites More sharing options...
Zues Marine Posted May 9, 2015 Share Posted May 9, 2015 I found these whilst perusing the internets and know they can be hard to find, especially with MU going down and such so i uploaded them to google drive. Factory Service Manuals: 19951996199719981999 OEM Parts Numbers Link to comment Share on other sites More sharing options...
subarunewb Posted May 11, 2015 Author Share Posted May 11, 2015 Which folder is the speaker section in? 1995 link. Link to comment Share on other sites More sharing options...
Gt_Legacy Posted May 12, 2015 Share Posted May 12, 2015 on the door panels there is 2 maybe 3 screws holding it in, one right inside the door handle and 2 by the cubby one on the side and one possibly in the cubby, then there is clips in the bottom just grab from the bottom and give it a pull, after that then you should be able to lift it out of the window edge and around the door handle. after that you should see the speaker then its just replacing and wiring new connectors. Link to comment Share on other sites More sharing options...
subarunewb Posted August 28, 2015 Author Share Posted August 28, 2015 on the door panels there is 2 maybe 3 screws holding it in, one right inside the door handle and 2 by the cubby one on the side and one possibly in the cubby, then there is clips in the bottom just grab from the bottom and give it a pull, after that then you should be able to lift it out of the window edge and around the door handle. after that you should see the speaker then its just replacing and wiring new connectors. Just now saw this. I will go check here in a few mins. Link to comment Share on other sites More sharing options...
1692 Posted August 31, 2015 Share Posted August 31, 2015 Here is a good write up with pictures that take you through step by step. Aside from removing the tweeters, it's exactly the same setup. http://forums.nasioc.com/forums/showthread.php?t=1730967 Link to comment Share on other sites More sharing options...
