stuck686 Posted April 29, 2015 Share Posted April 29, 2015 that is intermittent! it comes and goes. 89k miles I have 2 week old summer tires that should be nicely balanced (alignment done also), also a new clutch and new rotors as of last month. Car is 99% but has this annoying steering wheel shimmy around 65mph. sometimes i will take a corner or swtich lanes and it goes away and the wheel feels solid and planted. I have jacked the car and have no wheel play in tie rods, joints, bearings etc. My LCA bushings are prob shot, could these be responsible for this kind of steering play or should i look more towards steering rack bushings? Link to comment Share on other sites More sharing options...
ras06LGT Posted April 29, 2015 Share Posted April 29, 2015 LCA bushings will definitely cause this if they are worn/torn. Link to comment Share on other sites More sharing options...
whitetiger Posted May 4, 2015 Share Posted May 4, 2015 ^this. also jack the car ups and see if there is play in the wheel bearings, ball joints, or tie rods just to be sure. Link to comment Share on other sites More sharing options...
oncesir Posted May 6, 2015 Share Posted May 6, 2015 Just throwing this out there but what about a wheel weight that fell off? Inner cv joints ok? I know the inner boots usually rip and leak grease. Link to comment Share on other sites More sharing options...
whitetiger Posted May 6, 2015 Share Posted May 6, 2015 ^that is also very possible. Maybe even a bent wheel. Link to comment Share on other sites More sharing options...
Yonz Posted May 22, 2015 Share Posted May 22, 2015 Any luck? Link to comment Share on other sites More sharing options...
DonnyJagaru Posted May 29, 2015 Share Posted May 29, 2015 Sh*tty tires will cause this too. Link to comment Share on other sites More sharing options...
stuck686 Posted June 11, 2015 Author Share Posted June 11, 2015 Nope no luck. New LCA bushings are in. Feels nice and planted but free play still comes and goes. Thinking steering rack or bushings or something in the linkage not sure Link to comment Share on other sites More sharing options...
DonnyJagaru Posted June 11, 2015 Share Posted June 11, 2015 If it comes and goes its an issue involving two of the wheels. When they are in lock-step with each other you get the symptom. I say they aren't balanced properly is all. Link to comment Share on other sites More sharing options...
stuck686 Posted June 11, 2015 Author Share Posted June 11, 2015 now they are like month old tires and nicely balance. It feels more of like loose steering that happens and sometimes ill hit a turn or get on it and it changes to like the nice tight bmw steering feel and no shaking. Link to comment Share on other sites More sharing options...
