solo413 Posted April 3, 2015 Posted April 3, 2015 Hello all, I was looking for a new look for my 06 LGT and saw a few videos on the plastidip and decided instead of sanding and painting the gold rims I had I would try this plastidip stuff out. I ordered the color blurple with a metallic finish and watched a few how to videos from dipyourcar.com site! I have spray painted many things throughout my life with out issue and NO drips or runs! Well unknowingly I apart a few test spots on wood in my shed before I even think of touching the rims as I would with any paint and it comes out like gunked up trash, I shake cans more and go for a few more try's same issue switched out nozzles with better ones I had laying around same issue. Call up dipyourcar where I ordered the paint from they say this is normal and how it works so I say it peels off I'll try it and spray one rim!!!! The rim looked horrible and the paint, drips, runs and looks like a plastic fork compared to fine silverware. This is disappointing and regardless of being out the 65 it cost to buy as they will not supply refund I now will be sanding down the rims and going through primer and paint all over again. Before I washed and dryer the rims http://tapatalk.imageshack.com/v2/15/04/02/fb22077cfe48dcee390250d7681612cf.jpg Before close up (wasn't cleaned yet) http://tapatalk.imageshack.com/v2/15/04/02/b2ffbc938ca25e918af002e8f8d85b0b.jpg After sprayed 3 coats it still looks horrible! Called dipyourcar back and sent pictures they tell me it looks good and normal!!! Wow really!! http://tapatalk.imageshack.com/v2/15/04/02/f99367c86e75f86433325121746ea764.jpghttp://tapatalk.imageshack.com/v2/15/04/02/7d86bc015a3544833a96ebe28cd2e4a8.jpghttp://tapatalk.imageshack.com/v2/15/04/02/0f5da1ef2be5869d0b30a75867aa63fb.jpghttp://tapatalk.imageshack.com/v2/15/04/02/6ee73dee4bf4ef7a32a65726a74f122d.jpg
Kevin622 Posted April 4, 2015 Posted April 4, 2015 first coat you should only mist it on so the dip has something to adhere to when you spray the next coat a little heavier. You cant rush it take your time and dont soak one spot or it will have runs every where
solo413 Posted April 4, 2015 Author Posted April 4, 2015 first coat you should only mist it on so the dip has something to adhere to when you spray the next coat a little heavier. You cant rush it take your time and dont soak one spot or it will have runs every where Thanks for the info I was expecting it to be more like spray paint! I'm not really fan of it
parad1mg Posted April 4, 2015 Posted April 4, 2015 I use plastidip the same way as I use a rattle can spray paint. Prep is the same and first coats are per directions from the can. Never had runs or spots where it didn't lay flat. The only way anybody would end up with runs is if you spray it too heavy without moving the can and with bare spots if the surface was not thoroughly prepped. Anyway, I hope you'll have better luck and results the next time you attempt to use plastidip again.
solo413 Posted April 5, 2015 Author Posted April 5, 2015 I like the wheels. interested in selling them? Where you located at? I'm in Delaware and I would sell them for sure
BoyceWare Posted April 7, 2015 Posted April 7, 2015 I ran into a similar issue when painting my wheels, except it was only with one can. I emailed DYC and they asked for the batch numbers on the bottom of the can and let me know that it was part of a known defective batch and shipped me a new can at no cost. All other cans worked flawlessly, however I give the cans a hot water bath between coats.
solo413 Posted April 7, 2015 Author Posted April 7, 2015 I ran into a similar issue when painting my wheels, except it was only with one can. I emailed DYC and they asked for the batch numbers on the bottom of the can and let me know that it was part of a known defective batch and shipped me a new can at no cost. All other cans worked flawlessly, however I give the cans a hot water bath between coats. Thanks I might give it another try, when I called they told me the way the rims look is how it is supposed to look and that it was coming out good
BoyceWare Posted April 7, 2015 Posted April 7, 2015 Thanks I might give it another try, when I called they told me the way the rims look is how it is supposed to look and that it was coming out good Yeah I handled all mine through email. I let them know that one of the cans continued to clog up causing an uneven spray even after soaking the nozzle in paint thinner. They follow up quickly and mailed my replacement within a day or so.
Dujo Posted April 7, 2015 Posted April 7, 2015 If you decide to remove the dip and you are having trouble peeling it in some places where it's too thin, you can get it off there without sanding by using Goo Gone. Will dissolve the plastidip.
BoyceWare Posted April 7, 2015 Posted April 7, 2015 Here's a link to my dipped wheels: http://legacygt.com/forums/showpost.php?p=4753951&postcount=140
solo413 Posted April 7, 2015 Author Posted April 7, 2015 If you decide to remove the dip and you are having trouble peeling it in some places where it's too thin, you can get it off there without sanding by using Goo Gone. Will dissolve the plastidip. Thanks Dojo!
solo413 Posted April 7, 2015 Author Posted April 7, 2015 Here's a link to my dipped wheels: http://legacygt.com/forums/showpost.php?p=4753951&postcount=140 Those look great!
b_holm Posted April 8, 2015 Posted April 8, 2015 hold farther away and do lighter coats. and shake the hell out of the cans
Rhitter Posted April 8, 2015 Posted April 8, 2015 I have used it a couple times - as long as the can is warm and you don't spray it on too think I don't have any issues. - Anthracite http://i.imgur.com/d3OIOMD.jpg - Gold http://i.imgur.com/DLascu9.jpg - Black http://i.imgur.com/N2iVNIu.jpg?1 I start with really light dustings and try to keep moving quickly, 10-15 minutes between coats. Your third coat you should have complete coverage. It looks like you held the dip in one place for too long / maybe the can was cold. Plasti-dip is very forgiving and using you can cover up small mistakes by just adding more coats (unlike real paint) My OBXT build
wonka Posted April 8, 2015 Posted April 8, 2015 And just a heads up if anyone is thinking about getting gallons and Wagner sprayer. After a while the plasti dip might start drying in the nozzle and you'll need to clean it out. I didn't and ended up with a texture sprayed on my last coat.
GTEASER Posted April 8, 2015 Posted April 8, 2015 Plastidip really need to be sprayed at temperatures above 70 degrees. Any colder than that and it just doesn't lay out nice and gets lumpy. It also helps to use the clear glossifier over top of your color coat. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold
1-3-2-4 Posted April 29, 2015 Posted April 29, 2015 one side note these plastic dip cans (at least retail cans) the can is so thin shaking it was causing the ball inside to dent the underside of the can.. And I dropped the can by mistake and it ended up making a hole and a whole wasted can.. but when I did my wheels it was a bit windy and a little chilly so it make kind of a splatter mess on one wheel but not that noticeable. I will redo them this summer however.
solo413 Posted April 29, 2015 Author Posted April 29, 2015 I gave it another try with the suggestion but still not happy
solo413 Posted April 29, 2015 Author Posted April 29, 2015 The outcome before the clear coat was great but gloss clear coat had a silver sparkle tint that was ugly Happy with this http://images.tapatalk-cdn.com/15/04/29/e1bd0d38c9ad6397df5a3bc85be33833.jpg But this looks horrible http://images.tapatalk-cdn.com/15/04/29/dc0d3eb5607f110012a11d99f3dac9c4.jpg
2006 Subaru Legacy GT Posted May 10, 2015 Posted May 10, 2015 I have used it a few times. First go, I was to far away from the wheel. They came out looking and feeling fury. They were also a pain in the ass to remove because it was to thin of a coating. Second time, I put the first coat on thin and went heavier as I put more coats on. I stopped at three coats on three wheels and four on the last. I jumped the gun and stuck my finger in it. So I sprayed the last wheel with one more coat to cover the finger print. The fourth wheel is a little more bronze now than gold. They turned out pretty decent for never using spray cans before. I went with the antique gold. Take your time and don't rush. Grab a few beers and give it another go.
Shogun506 Posted May 11, 2015 Posted May 11, 2015 I plastidipped my motorcycle helmet last year and it looked great. I love the flat finish it gives things. Make sure you keep extra cans for touch up as you'll probably get parts where the plastidip chips over time from getting hit with rocks etc from the road.
