samcuomo Posted April 1, 2015 Share Posted April 1, 2015 Does anyone happen to know what size/thread pitch the intercooler brace bolts that thread into holes on the manifold are? Link to comment Share on other sites More sharing options...
magnusonsubie Posted April 1, 2015 Share Posted April 1, 2015 Can you post a picture of the location you are talking about? I believe you may be talking about the flange between the turbo and intercooler or the one on the drivers rear corner. I can take any of mine off and measure them if you just let me know which bolts you are talking about. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
samcuomo Posted April 1, 2015 Author Share Posted April 1, 2015 I circled them in red on this picture. http://i62.tinypic.com/14jlutu.jpg Link to comment Share on other sites More sharing options...
magnusonsubie Posted April 1, 2015 Share Posted April 1, 2015 Okay. Simple enough I will measure them when I am out of class in an hour. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
samcuomo Posted April 1, 2015 Author Share Posted April 1, 2015 Thanks dude! I appreciate it! Link to comment Share on other sites More sharing options...
MrTris Posted April 1, 2015 Share Posted April 1, 2015 Should be m6x1.0 or 1.25, if a finer thread. Link to comment Share on other sites More sharing options...
zactek Posted April 2, 2015 Share Posted April 2, 2015 I'm pretty sure they're M8x1.25, I've been replacing all the bolts with stainless lately.... Link to comment Share on other sites More sharing options...
magnusonsubie Posted April 2, 2015 Share Posted April 2, 2015 I'm pretty sure they're M8x1.25, I've been replacing all the bolts with stainless lately.... I think that's what they are too. I couldn't get into the machine shop yesterday to check for sure though. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
MrTris Posted April 2, 2015 Share Posted April 2, 2015 If the're a 10mm head, they're m6. If 12, they're m8. Link to comment Share on other sites More sharing options...
zactek Posted April 2, 2015 Share Posted April 2, 2015 If the're a 10mm head, they're m6. If 12, they're m8. Yep. A lot of the aftermarket/stainless M8-threaded bolts come with a 13mm head, although the M6's still all come with a 10mm head..... Zack K. Link to comment Share on other sites More sharing options...
MrTris Posted April 2, 2015 Share Posted April 2, 2015 Yep. A lot of the aftermarket/stainless M8-threaded bolts come with a 13mm head, although the M6's still all come with a 10mm head..... Zack K. This is true! Such as in the case where one buys the GS 8mm spacers that come with new, longer intake manifold bolts -- 13mm heads on 'em. Link to comment Share on other sites More sharing options...
samcuomo Posted April 3, 2015 Author Share Posted April 3, 2015 Great! I'll have to get two and try them out! Thanks guys! Link to comment Share on other sites More sharing options...
JmP6889928 Posted April 3, 2015 Share Posted April 3, 2015 8x1.25x1" Link to comment Share on other sites More sharing options...
