stajerker Posted March 25, 2015 Share Posted March 25, 2015 Hey all, In the middle of replacing my rear rotors/pads, and just got off the calipers and took off the slide pins - however, i didnt realize they were different (one has the little rubber bushing on it) and so I dont know which pin goes on which side. From searching, it looks like the pin with the rubber bushing on it goes in the lower part of the caliper - is this correct? pic: https://www.dropbox.com/sc/07tzr2echq26ttf/AACkRDU4TxlBjNNqNjpmFpyVa Link to comment Share on other sites More sharing options...
ras06LGT Posted March 25, 2015 Share Posted March 25, 2015 Both slide pins should have the rubber boot on them. Here's the exploded view of the rear caliper. http://opposedforces.com/parts/legacy/us_b13/type_7/brake_system/rear_brake/illustration_3/ Link to comment Share on other sites More sharing options...
orndog Posted March 25, 2015 Share Posted March 25, 2015 He's not talking about the boots, but the pin with the rubber tip. I can't help you OP, it does look like lower. For the future, always takes cell phone pics as you disassemble. Link to comment Share on other sites More sharing options...
stajerker Posted March 25, 2015 Author Share Posted March 25, 2015 ah that diagram does help thanks! its the little nub listed as 'a5' on the bottom slide pin! Thanks for the help ps: hard to take pics with hands covered in brake cleaner/grease/pb blaster. Link to comment Share on other sites More sharing options...
orndog Posted March 26, 2015 Share Posted March 26, 2015 ah that diagram does help thanks! its the little nub listed as 'a5' on the bottom slide pin! Thanks for the help ps: hard to take pics with hands covered in brake cleaner/grease/pb blaster. It's even harder to post on a car forum in the same condition I learned to take pics after tearing down the drum brakes on my 1969 Camaro. Now it's just a step I do. Link to comment Share on other sites More sharing options...
FJuan Posted March 26, 2015 Share Posted March 26, 2015 The one with the rubber slide pin goes on the bottom. I've took all the rubber off all my pins, since they became worn out and caused the pins to seize. Doesn't create any issues if you do. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
ras06LGT Posted March 30, 2015 Share Posted March 30, 2015 Sorry, didn't even notice that little rub nub was on there. Glad it doesn't matter, because I don't remember that on mine when I did my rear brakes, and I'm sure I didn't pay attention to make sure it was there when re-assembled. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 31, 2015 Share Posted March 31, 2015 Yes, other members have talked about removing that collar around the bottom of the slide pin too. Hint, make sure you get that rubber dust boot sealed on the bracket...if you don't water will get in there and rust will form. New brackets come from the dealer for like $80 each... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
quick4dr Posted April 17, 2015 Share Posted April 17, 2015 New bracket doesn't come with sliders/ boots or hardware last I checked. I've always been told by elders the rubber is there for harmonics and dampening. If maintenance and lubed no issues if it dries out its adheres to the bracket wall and makes removal a bitch Link to comment Share on other sites More sharing options...
FJuan Posted April 18, 2015 Share Posted April 18, 2015 Not so much that it dries out, it becomes very mushy over time and the actual rubber becomes softer/stickier, causing it to seize inside. All mine became like that, and I would lube them everytime I changed the pads. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
