Matt166 Posted August 15, 2015 Share Posted August 15, 2015 Is your fork/push rod all the way back in with the clutch released? If so I would guess its air in the system/something to do with the pedal assy. TOB failure will cause the pedal to not release, but youll see it when you look at the tranny as the push rod will be stuck in the extended position (or half extended in your case) Link to comment Share on other sites More sharing options...
Spooph Posted August 15, 2015 Author Share Posted August 15, 2015 nope, definitely not lower, higher than the master cylinder at one point, but never lower than it's mounted to the transmission. I've gone to bleeding the master cylinder. I've been bleeding for about an hour now, and every once in a while there are a bunch of bubbles that come out. It's also not drawing from the reservoir, however, I can fill the reservoir by back-flowing the system with a syringe.... It's almost as if there is a leak in the master cylinder. I have adjust the pedal about 3/4 turn. Could this be limiting the range of motion enough to be unable to move past the low pressure hole in the master cylinder? OR is there a big leak somewhere? Maybe on the reservoir to master cylinder seal? You'd think I'd be seeing fluid pushed out of there if that were the case though? Link to comment Share on other sites More sharing options...
Spooph Posted August 15, 2015 Author Share Posted August 15, 2015 What is also weird, is half way through the stroke the pedal just goes to the floor. Shouldn't it always return to it's "out" position? Maybe the spring on the piston broke? Link to comment Share on other sites More sharing options...
Spooph Posted August 16, 2015 Author Share Posted August 16, 2015 Turns out, adjusting the clutch pedal can cause the master cylinder piston not to work properly, leaving the low pressure circuit to the reservoir closed. Adjusted the pedal down as far as it would go, and the system bled just fine. All is working again. Link to comment Share on other sites More sharing options...
Spooph Posted August 18, 2015 Author Share Posted August 18, 2015 Replaced the driver side half shaft seal and o-ring and now I just gotta put it together. I'm sure you guys are tired of hearing these updates, as they simply repair and nothing new, however, I find all of this very scary, so I like to share my victories. EDIT: As projects go, and I view this as a project, it evolves. As you work on the vehicle, you notice other things that need to be done. I will be making a new custom faceplate for the stereo and adding a dual band Ham radio to the car. Should I create new threads for those, or just keep posting updates here? Link to comment Share on other sites More sharing options...
StkmltS Posted August 18, 2015 Share Posted August 18, 2015 I like your updates. It's encouraging to hear that I'm not the only idiot person spending oodles of $$$ on the whack-a-mole game that I call "Owning a Subaru" I think your custom faceplate and ham radio projects will be interesting to follow, but they probably belong in their own threads. Making separate threads will keep this one true as a turbo/engine thread, and your other projects will probably get better and more input if they're in the interior/audio forum. My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
Spooph Posted August 29, 2015 Author Share Posted August 29, 2015 Going through my photos and found a couple I still need to upload. TMIC before. Link to comment Share on other sites More sharing options...
Spooph Posted August 29, 2015 Author Share Posted August 29, 2015 TMIC after going through it with a fin comb. Link to comment Share on other sites More sharing options...
rmoore5 Posted August 29, 2015 Share Posted August 29, 2015 ^ Don't you love auto-correct it's "fun". Link to comment Share on other sites More sharing options...
Spooph Posted August 31, 2015 Author Share Posted August 31, 2015 I do! thanks, fixed. Link to comment Share on other sites More sharing options...
Spooph Posted October 7, 2015 Author Share Posted October 7, 2015 Attached is the oil report from Blackstone. Looks like for now I'm running pretty. Going to send another sample after 3,000 miles, and then at 10K (If I make it that far). I will also be updating the first page with this info. Link to comment Share on other sites More sharing options...
Horm2124 Posted October 8, 2015 Share Posted October 8, 2015 Glad to hear it. I am in the same boat with the blow turbo right now. Nice to see turbo failure isn't always the death of your short block. Link to comment Share on other sites More sharing options...
Spooph Posted October 9, 2015 Author Share Posted October 9, 2015 Glad to hear it. I am in the same boat with the blow turbo right now. Nice to see turbo failure isn't always the death of your short block. I sure hope so! No guarantee, but for now the numbers are looking good! AMileHighGT only got 5K out of his fixed turbo before spinning a rod bearing, so, we'll see how the dice falls for me. Link to comment Share on other sites More sharing options...
Horm2124 Posted October 9, 2015 Share Posted October 9, 2015 Hope it work out. Link to comment Share on other sites More sharing options...
Spooph Posted December 30, 2015 Author Share Posted December 30, 2015 just got the results back from Blackstone - 4,715 miles currently on the engine post turbo replacement and they say I can extend my OCI from 3K to 5K on Rotella T6 and WIX filters... Again, super thanks to this awesome community. I'm not here often as my car isn't my hobby, but keep up the good work. Super thanks! Link to comment Share on other sites More sharing options...
Scruit Posted December 31, 2015 Share Posted December 31, 2015 What is the turnaround time for Blackstone? I have some of their oil tubs and I was going to have them do an analysis on my oil at the end of the 1000 mile breaking before I get into tuning. Link to comment Share on other sites More sharing options...
Spooph Posted January 4, 2016 Author Share Posted January 4, 2016 It has varied greatly, from 2 months to 1 week. On average it takes about 3 weeks to get results back. Link to comment Share on other sites More sharing options...
Spooph Posted April 6, 2016 Author Share Posted April 6, 2016 So put 5,000 miles on the last Rotella T6 and Blackstone has reported the engine is showing less wear than average (compared to other Subaru LGT's from the same year). This puts the turbo replacement, oil system rebuild and stock re-tune from Cryotune at over 10K miles of use, some pretty damn hard. From here on out I will be sending in samples every 10K or so to see how things are looking and keep reporting back. Looks like I got really lucky. Thanks again for all your help in getting me back on the road. Link to comment Share on other sites More sharing options...
