Scubaboo Posted April 28, 2020 Share Posted April 28, 2020 Thanks! Those look to be the same style I got for my boost gauge install, working well for a while now. Link to comment Share on other sites More sharing options...
JDMBR9 Posted April 28, 2020 Share Posted April 28, 2020 I just did this install yesterday. There are no instructions for our car specifically on their website. This one is close https://www.grimmspeed.com/content/install_guides/GrimmSpeed_FA20_boost_control_solenoid_Install_Guide.pdf The primary difference is the solenoid itself is separate from the adapter plate. You have to mount it somewhere under the hood. I used the hole on the lower tie bar where the peg on the passenger side of the radiator sits. Port 1 goes to the intake port Port 2 goes to the wastegate Port 3 goes to the turbo port You will need 2 hose adapters to go from the smaller hose of the wastegate and turbo to the hose that comes with the unit. If your hoses are old and hard, get a foot of the small hose. I believe its 4mm ID to 6mm ID. I brought the hoses with me to Autozone to fit the adapters please could you post some pictures? Link to comment Share on other sites More sharing options...
poconoracing Posted April 28, 2020 Share Posted April 28, 2020 please could you post some pictures? Here you go.... I'll clean up the hoses and put the undercover back on once tuning is done. Link to comment Share on other sites More sharing options...
