PtPixel Posted February 23, 2015 Share Posted February 23, 2015 I'd be looking at early 2000's WRX or LGT over here for those requirements. You'd definitely need to factor in maintenance for an older vehicle but I imagine the older Subarus would be cheaper to maintain than VWs or Audis of the same generation. some mods can be done to the GT to get better mpg and still have the power. Unless you're gong to rip out the passenger seats & trunk / swap out for skinny tyres / cover all cracks with duct tape then what ever you spend to reduce MPG will likely not return any savings. Link to comment Share on other sites More sharing options...
Tehnation Posted February 23, 2015 Share Posted February 23, 2015 #YOLO! Get the lgt! Do it! Link to comment Share on other sites More sharing options...
Tehnation Posted February 23, 2015 Share Posted February 23, 2015 http://legacygt.com/forums/showthread.php/my05-09-legacy-gt-common-issues-230230.html Link to comment Share on other sites More sharing options...
Kcids Posted February 23, 2015 Author Share Posted February 23, 2015 I am going to look at a white '06 LGT Limited for 7k, 133k miles with upgraded turbo (35k ago) BNR stage 1, EVO 16G compressor wheel/TD05H turbine wheel (max-rated at 300 WHP) along with both OCV solenoids. He also recently replaced the O2 sensors, front brakes, and belts. Car has practically zero rust. Gonna try to talk him down a bit. Link to comment Share on other sites More sharing options...
