5280GT Posted February 6, 2015 Share Posted February 6, 2015 I got bored and attempted driving much too vigorously around the Colorado mountains and this happened..... http://tapatalk.imageshack.com/v2/15/02/06/24f22b279bbcea78fe95b29fc220ebe4.jpg Body work or replacement of the door/roof panel or just the sh**storm, aka an 8ft tall sapling???? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted February 6, 2015 Share Posted February 6, 2015 The roof is going to be the hard part to fix. That won't be cheap. The door they can put a new skin on it. Someone backed into me the cost was almost $2000 to replace the door skin. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
5280GT Posted February 6, 2015 Author Share Posted February 6, 2015 The roof is going to be the hard part to fix. That won't be cheap. The door they can put a new skin on it. Someone backed into me the cost was almost $2000 to replace the door skin. Faaaaaaaacccccckkkkkkk!!!!! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
5280GT Posted February 6, 2015 Author Share Posted February 6, 2015 Should I try the dry ice trick on the roof? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
BoyceWare Posted February 6, 2015 Share Posted February 6, 2015 No way dry ice or canned air will work on body lines or that much damage. Link to comment Share on other sites More sharing options...
5280GT Posted February 6, 2015 Author Share Posted February 6, 2015 No way dry ice or canned air will work on body lines or that much damage. Thanks, never knew the abilities of either.... Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted February 6, 2015 Share Posted February 6, 2015 Yep, think about all the labor involved in replacing the door skin and changing over the stuff inside the door. The door is much better then the door that came on the car, it's very tight. It was the drivers side rear door that got backed into. You may be able find a junkyard door. www.car-part.com The roof is a bigger problem. The head liner will have to be removed and the dent pushed out or a piece cut out and replaced. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
doubleoughtgt Posted February 7, 2015 Share Posted February 7, 2015 Subaru doesn't sell skins for doors. You will have to replace the shell itself. But from the picture it looks fixable. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
MrTris Posted February 7, 2015 Share Posted February 7, 2015 I suppose OP is underinsured, too? It'd go down as an at-fault accident, but, since it's by definition a collision, you should make your claim and pay the deductible. To be honest with you, that kind of damage could very likely end up in a TL situation. Link to comment Share on other sites More sharing options...
doubleoughtgt Posted February 7, 2015 Share Posted February 7, 2015 I don't know what the percentage of damage in your state is to consider it a total but, in North Carolina it's 75% of actual cash value. Even if you had to replace the door with a oem shell, blend accordingly and repair that dent in the C pillar your looking at 2500-3000 at best. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
MrTris Posted February 7, 2015 Share Posted February 7, 2015 I don't know what the percentage of damage in your state is to consider it a total but, in North Carolina it's 75% of actual cash value. Even if you had to replace the door with a oem shell, blend accordingly and repair that dent in the C pillar your looking at 2500-3000 at best. Sent from my iPhone using Tapatalk All of these cars have pearlescent paint, which is, from what I understand, quite difficult to blend properly. The time and and labor involved, in addition to any parts or fab work needed, as well ass the possibility of repainting the entire car would likely total it out. And if the C-Pillar turned into frame damage, it's game over. Total cost is likely double your estimate, which would put it well into TL territory -- Car's really only worth about $7500-8900. Link to comment Share on other sites More sharing options...
doubleoughtgt Posted February 7, 2015 Share Posted February 7, 2015 Well considering I've been writing damage for 20 years I'm pretty confident in my opinion. These cars do not all have 3 stage paint. And any competent painter would be able to blend the paint. And you're correct In The assumption that painting the entire car would total it. But no insurance company would pay to refinish the entire vehicle. And would more then likely ask for a spray out panel to be perform before even paying for a blend panel. This is my everyday. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Leviman Posted February 7, 2015 Share Posted February 7, 2015 Yeah, but that sounds like you work for a good shop, not a shop that selectively bids high on jobs they don't want to do . If you're okay with a bit of a hack, you could probably use fiber reinforced filler on the pillar, and replace the door with a junkyard one. Blend the paint, good to go. Link to comment Share on other sites More sharing options...
5280GT Posted February 9, 2015 Author Share Posted February 9, 2015 Since I am over 25, my deductible took a nose dive. Praise Jeebus for insurance Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
