Th3crack3r Posted February 2, 2015 Share Posted February 2, 2015 Hey guys, 10k after the head gasket job, still good. Replaced my rad hoses. I just found out my oil pan drain is totally stripped. installed a rubber plug for the moment, but I have to change the oil pan, it s leaking a lot of oil... It was spotted with rust anyway... I only found one maker, PIONEER Part # 501151 160$. Can I install a STI or WRX oil pan without fitting issue ? They charge me 425$ plus tax, around 500 quids for the job at the local garage. I plan on doing it myself but want your advices first. I also found a cork fel pro gasket and a rubber one, victor. What about them vs RTV grey stuff. Thanks Jeff Link to comment Share on other sites More sharing options...
Max Capacity Posted February 2, 2015 Share Posted February 2, 2015 Pay the man, Unless your good with tools and can lift the engine a bit. Even with my engine on a stand the pan was a bitch to get off the pick up tube. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted February 2, 2015 Moderators Share Posted February 2, 2015 I didn't think the oil pan reinstall was that bad, but I also had my headers off. Loosen engine mounts and pitch stop, jack up motor a bit, remove pan, reinstall. I used Permatex grey gasket maker. Pretty sure you want to use something similar. Black or grey should work. Lots of folks use somthing called "Right Stuff" i think. I don't think anyone really uses a cork/rubber pre-made gasket. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
CloudSeed777 Posted February 2, 2015 Share Posted February 2, 2015 My new oil pan was $100 from Subaru. Might look at that option. I used Ultra Grey for mine. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted February 2, 2015 Moderators Share Posted February 2, 2015 And if you get a new pan from Subaru, see if you can go with an 06+ STi pan. It will mount up, and has some better baffling and better shape to accomodate aftermarket headers. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Th3crack3r Posted February 2, 2015 Author Share Posted February 2, 2015 My new oil pan was $100 from Subaru. Might look at that option. I used Ultra Grey for mine. was 180$+tx at the stellarship. Think I'll just pay the man and forget about it... warranty saved my ass a few times already... Jeff Link to comment Share on other sites More sharing options...
MrTris Posted February 2, 2015 Share Posted February 2, 2015 +1 for no gaskets. Use Permatex UltraBlack or Grey. Link to comment Share on other sites More sharing options...
