Canon20D Posted January 14, 2015 Share Posted January 14, 2015 My seat heater in my 05 (MY05, 04 production) get significantly uncomfortable after a few minutes of high. Its not a problem really as it heats up nice and quick, but its annoying. So when I got my Seek thermal camera, I investigated the cause. see below: So you can see the top is nice an uniform. The bottom is all scrunched up and makes a mess. Gets real hot, but then i have to turn it down and it doesnt really make the seat warm, just that one spot. TL;DR: How hard is it to remove the seat cover, and access the wires for the seat heater. I think on one of my subarus i remember a zipper or something that you could undo to take the seat apart. Even if I can, are those wires buried in the padding? Whats it going to take for me to fix? Link to comment Share on other sites More sharing options...
ras06LGT Posted January 14, 2015 Share Posted January 14, 2015 That's a cool picture. Here's a really detailed walkthrough of what you need to do to fix it. http://legacygt.com/forums/showthread.php/fix-your-heated-seat-106069.html Link to comment Share on other sites More sharing options...
MrTris Posted January 14, 2015 Share Posted January 14, 2015 Here's a good start: http://legacygt.com/forums/showthread.php/fix-your-heated-seat-106069.html And if you're not feeling entirely up to replacing things, and just want to investigate for now: http://legacygt.com/forums/showthread.php/seat-heater-stopped-working-148974.html Link to comment Share on other sites More sharing options...
Canon20D Posted January 14, 2015 Author Share Posted January 14, 2015 Well crap! thats a lot of GD work to get to those things. No wonder my wifes forester had to be replaced and it took 3 hours. i think ill live with it as is, at least it gets hot Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 16, 2015 Share Posted January 16, 2015 Here's a good start: http://legacygt.com/forums/showthread.php/fix-your-heated-seat-106069.html And if you're not feeling entirely up to replacing things, and just want to investigate for now: http://legacygt.com/forums/showthread.php/seat-heater-stopped-working-148974.html I need to try and do my drivers seat when the weather warms up Link to comment Share on other sites More sharing options...
MrTris Posted January 16, 2015 Share Posted January 16, 2015 I need to try and do my drivers seat when the weather warms up Me, too, unfortunately. Link to comment Share on other sites More sharing options...
Redryan98 Posted January 16, 2015 Share Posted January 16, 2015 I have the same issue with my seat. Gets way too hot in one spot. Good to know I'm not the only one. When I had my LGT I pulled the leather off the bottom part of the seat a couple times. Its really not bad at all. Once the seat is out of the car I think its only 6 bolts. Get good hog ring pliers and follow the DIY and it shouldn't take more than a couple hours. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 16, 2015 Share Posted January 16, 2015 I have the same issue with my seat. Gets way too hot in one spot. Good to know I'm not the only one. When I had my LGT I pulled the leather off the bottom part of the seat a couple times. Its really not bad at all. Once the seat is out of the car I think its only 6 bolts. Get good hog ring pliers and follow the DIY and it shouldn't take more than a couple hours. Where do you find hog ring pliers? And say it's a broken wire where is it at? I skimmed over that seat heater fix quick one day but I think the spring coil is what causes it to kill the power to the seat heater? Link to comment Share on other sites More sharing options...
Redryan98 Posted January 16, 2015 Share Posted January 16, 2015 Where do you find hog ring pliers? And say it's a broken wire where is it at? I skimmed over that seat heater fix quick one day but I think the spring coil is what causes it to kill the power to the seat heater? Not sure, I think amazon or ebay. Bought a hog ring pliers and a bunch of hob rings for $25 I think Not sure about fixing the existing seat heater. I believe you'd be better off just buying a new one from Subaru Link to comment Share on other sites More sharing options...
MrTris Posted January 16, 2015 Share Posted January 16, 2015 Not sure, I think amazon or ebay. Bought a hog ring pliers and a bunch of hob rings for $25 I think Not sure about fixing the existing seat heater. I believe you'd be better off just buying a new one from Subaru This. There's a PN in the thread(s) I linked. Link to comment Share on other sites More sharing options...
oncesir Posted January 18, 2015 Share Posted January 18, 2015 I just fixed the driver side heater in my 05 lgt wagon. The heater wire was broken on the bottom and the seat back portion. Resoldered the wires. Works great now. It's easy to take the cover off. I love me some butt heat. Link to comment Share on other sites More sharing options...
