shocker73 Posted January 8, 2015 Share Posted January 8, 2015 OK, long story short. Just had the motor in my 2010 legacy limited replaced by a highly reputable tech. Since the new motor has been in, the blue temperature indicater stays on 30+ min. longer now due to winter. Also the ABS, traction control and BRAKE indicator lights are on. If I disconnected the battery & reconnect, these lights remain off until cruise is set. These are two separate problems, so I'm sorry this may be confusing but if anyone has any ideas or questions I will try to elaborate. Thanks Link to comment Share on other sites More sharing options...
GEE-OTTO Posted January 9, 2015 Share Posted January 9, 2015 The temp light ma be due to the incorrent Thermo in the water pump i.e. temp rating too low allowing cold coolant to flow earlier i.e. the engine stays colder for longer. Do the other lights blink or constantly burn? If they are blinking that is good as you can pull the code and it wil tell you exactly whats wrong. If they are solid something may be connected improperly or disconnected all together or maybe a fuse blew. See if your car has any trouble codes stored in the ECU first as that will pinpoint the issue(s). Link to comment Share on other sites More sharing options...
shocker73 Posted January 9, 2015 Author Share Posted January 9, 2015 Check engine & traction control stay on. Cruise & brake blink continuously. Link to comment Share on other sites More sharing options...
moral hazard Posted January 12, 2015 Share Posted January 12, 2015 Get the ecu scanned for fault codes. That will tell you ehays wrong. Hopefully something simple. I would take it to the place that swapped the engine. They should scan it for free. Link to comment Share on other sites More sharing options...
Fabius Posted January 17, 2015 Share Posted January 17, 2015 Check engine & traction control stay on. Cruise & brake blink continuously. when my o2 sensor went i had the same codes. could be a spark plug fault as well. Link to comment Share on other sites More sharing options...
06leg315 Posted January 19, 2015 Share Posted January 19, 2015 If the mil illuminates then it generally cuts out cruise,abs, trac.. So I agree with moral hazard, get the fault codes and I'm sure you'll find its an engine code andthe other lights are simply on because the computer cuts those systems to try and protect itself. Link to comment Share on other sites More sharing options...
