o2fst4uo Posted December 26, 2014 Share Posted December 26, 2014 As per title, has anyone done it? I found a few guides that actually show it's very very easy to do with OEM parts. All you need is the steering wheel buttons and a 4-pin brake pedal switch, the ECU does the rest. When I get my parts I'll take as many photos as I can because I'm surprised there's no info on LGT about it at all! I was stunned when I found out this could be done for under $100 NZD To those who have done it (if any) what sort of hiccups did you come across? Link to comment Share on other sites More sharing options...
danci1973 Posted December 26, 2014 Share Posted December 26, 2014 Should the ECU automatically recognize new stuff and enable cruise control or will that take a trip to the dealer to enable it via Subaru Select Monitor? Link to comment Share on other sites More sharing options...
o2fst4uo Posted December 26, 2014 Author Share Posted December 26, 2014 My extensive research, and confirmation from others who have done it on another forum shows that you just plug and play. When you turn the car back on it detects the new components and shows a loading bar (no one knows what it says because we all have JDM models with Japanese writing on the dash). Then boom, you now have cruise control. Lights on the dash may or may not be there/work but that's not too important Link to comment Share on other sites More sharing options...
Lassiv Posted January 10, 2015 Share Posted January 10, 2015 Hi I hava Legacy B4 2.0GTAutomatic transmission, JDM model too. I buy legacy cruise switch that and connect that to connector inside steering wheel. All seems very good when i put key in ON position Cruise and Set light work on. I am very happy because think that work now.. i left test driving, but not get any situation that SET light come on. Cruise light goes ok when i put that switch top of cruise, and get that OFF too. But i try move switch every direction long/and short tryouts, i also try different speed and sport/D situations in automatic gear box. But that SET light not come ON and speed not set. I just check and my brake switch is 2wires model, but not see any wiring connector near that what have 4wires? Or do not need 4wires model in JDM versions or automatic versions? Now i try to get my battery disconnected about 5minutes and put that back on but not helping. That loading bar needs to show in navigation touch screen? I am very thankfull if some one can help my with this situation. Link to comment Share on other sites More sharing options...
NewZealandLegacyGTB Posted May 26, 2016 Share Posted May 26, 2016 As per title, has anyone done it? I found a few guides that actually show it's very very easy to do with OEM parts. All you need is the steering wheel buttons and a 4-pin brake pedal switch, the ECU does the rest. When I get my parts I'll take as many photos as I can because I'm surprised there's no info on LGT about it at all! I was stunned when I found out this could be done for under $100 NZD To those who have done it (if any) what sort of hiccups did you come across? Hi where is the writeup on the parts needed etc? Link to comment Share on other sites More sharing options...
Andy_Mac Posted May 26, 2016 Share Posted May 26, 2016 Check out clubsub.org.nz http://clubsub.org.nz/forum/showthread.php?46763-Help-with-fitting-cruise-control&highlight=Cruise+control http://clubsub.org.nz/forum/showthread.php?42250-Fitting-cruise-control&highlight=Cruise+control 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
NewZealandLegacyGTB Posted May 27, 2016 Share Posted May 27, 2016 Thanks Andy I spoke to Crowesport today and they said it cant be done on the 2.5ltr outbacks at all as they dont have the wiring loom to accept the addon. They have retrofitted cruise onto 3.0 and legacy 2.0 etc but cant do outback 2.5 Link to comment Share on other sites More sharing options...
BDII Posted May 27, 2016 Share Posted May 27, 2016 Your NZ models don't have cruise? Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
Alphius Posted May 27, 2016 Share Posted May 27, 2016 There are a lot of JDM imports in NZ, and very few JDM cars of any brand were offered with cruise control. Here in the US/Canada, all 4th gen Legacys have cruise control so retrofitting isn't something we would know a whole lot about. Link to comment Share on other sites More sharing options...
BDII Posted May 27, 2016 Share Posted May 27, 2016 Interesting Any idea why? I mean, I know Asians are terrible drivers but.... Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
