1-3-2-4 Posted December 13, 2014 Author Share Posted December 13, 2014 I took the dipstick out while it was idling and you can see the puff of smoke coming from it I'm not sure how the OCV works but it can't over pressurized the oil system right? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted December 13, 2014 Share Posted December 13, 2014 U can also do what I called the puf puf test where u take the oil cap off while idling and see if u see vapor pulsating in phase with the rpm. If u only see some vapor at first and no pulsating afterwards u should be OK ringland wise. But if it pulsates in phase with the rpm, then it's no good Link to comment Share on other sites More sharing options...
1-3-2-4 Posted December 13, 2014 Author Share Posted December 13, 2014 It goes in phase with the rpm.. im deciding if I want to do a used ej255 block for like $500 or ej22e with the 255 heads The other thing is to remove the pistons but not too keen because I've only taken one motor apart and it was just a learning session. . My biggest fear is getting the wrist pins back in place Link to comment Share on other sites More sharing options...
AF_3C2 Posted December 13, 2014 Share Posted December 13, 2014 Don't bother with either- pay the $1800 to Heuberger for a complete stock short block delivered to your door. Then you won't have to mess with building the block- just tearing the motor out and sending your heads in for a refresh. There will be other incidentals- when my shop tore mine out they had to replace the intercooler to IM coupler, valve cover cross pipe (hard line), and a bunch of other misc. rubber lines. If you go with the used options, you will only be putting a temporary band aid on the situation- especially since either way you are going to have to take your motor out and dismantle it..... Link to comment Share on other sites More sharing options...
xt2005bonbon Posted December 14, 2014 Share Posted December 14, 2014 Sorry to hear op Link to comment Share on other sites More sharing options...
1-3-2-4 Posted December 14, 2014 Author Share Posted December 14, 2014 I just remembered I need to get the tool to remove the intake cams Link to comment Share on other sites More sharing options...
1-3-2-4 Posted December 16, 2014 Author Share Posted December 16, 2014 I got around to changing the OCV today.. note to others don't pry on the body of the OCV and the bracket.. ended up snapping the part that sticks in the part for the oil.. I ended up just using some vice grips to break off that stupid zip tie on the hose to the valve cover. Anyways rough idle is still a little rough but I noticed my dipstick has not popped up in the last two drives. I was also told to wait and measure the pistons before just going and buying the piston rings? No one seems to know what size the stock pistons are.. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted December 16, 2014 Author Share Posted December 16, 2014 Don't bother with either- pay the $1800 to Heuberger for a complete stock short block delivered to your door. Then you won't have to mess with building the block- just tearing the motor out and sending your heads in for a refresh. There will be other incidentals- when my shop tore mine out they had to replace the intercooler to IM coupler, valve cover cross pipe (hard line), and a bunch of other misc. rubber lines. If you go with the used options, you will only be putting a temporary band aid on the situation- especially since either way you are going to have to take your motor out and dismantle it..... It's $1810 from subaru parts for you how big is the box the short block comes in? If I go this way I know for sure it wont be until late or early feb before I can start this.. Link to comment Share on other sites More sharing options...
Merc6 Posted December 17, 2014 Share Posted December 17, 2014 I can measure the box when I get home but it's not that big. I had the entire long block in the trunk of my 98 Buick when I drove from dealer to hole in the wall shop trying to get the cam gear bolts off. I can't speak on shipping as it just so happen to be sitting in the dealership. The parts guy always had 1 or 2 in stock as he was rebuilding another 05 that blew up shortly after trade in. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
1-3-2-4 Posted December 17, 2014 Author Share Posted December 17, 2014 lol I know the shortblock would fit but I don't want to have to take it out of the box to make it fit until I get to the location of the work being done. i'm not going to ship since the dealer internet location is only 30 miles away Link to comment Share on other sites More sharing options...
