TakmaN Posted December 3, 2014 Share Posted December 3, 2014 After doing some minor DIY mods this past weekend, I noticed my car starts to make a minor hissing/squealing sound on a cold start when I press in the clutch pedal. I'm due for a clutch change but never heard this sound before and it goes away when my car warms up. It sounds like it's coming from somewhere in the engine bay and the hiss sounds like what my SPT intake makes when driving but a little more "squealy". It only happens when I press in the clutch. Not sure if it's a coincidence or I messed something up when doing some mods in the garage last weekend but I did install a heat shield and had to remove some bolts off of the intercooler to wiggle it in. Otherwise the only other things I touched in the engine bay were the turn signal bulbs. Any ideas what this sound is? Link to comment Share on other sites More sharing options...
doobaruGT Posted December 3, 2014 Share Posted December 3, 2014 Throw Out Bearing. Buy a TSK3 kit when doing your clutch. Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
GEE-OTTO Posted December 3, 2014 Share Posted December 3, 2014 Its the TOB and if you neglect this issue you will need a TSK3 kit. Replace it along with your clutch and PP. Link to comment Share on other sites More sharing options...
TakmaN Posted December 3, 2014 Author Share Posted December 3, 2014 Throw Out Bearing. Buy a TSK3 kit when doing your clutch. Ah that makes sense. So it seems to be just a coincidence with the timing along with doing some DIY mods. I read that cold weather tends to make the squeal more noticeable and it calms down when it gets warm. Link to comment Share on other sites More sharing options...
TakmaN Posted December 3, 2014 Author Share Posted December 3, 2014 Its the TOB and if you neglect this issue you will need a TSK3 kit. Replace it along with your clutch and PP. Should I just get a TSK3 kit installed as a preventative measure? New clutch kit and flywheel are on its way but was thinking of adding this just in case. Also, does the TSK3 sleeve kit come with a bearing or do I need to order that separately? Link to comment Share on other sites More sharing options...
Max Capacity Posted December 3, 2014 Share Posted December 3, 2014 When its out, you may want to grease the shaft on the starter also. There's a sticky here somewhere about it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
AF_3C2 Posted December 3, 2014 Share Posted December 3, 2014 Most kits should come with the bearing- but verify at purchase. Link to comment Share on other sites More sharing options...
