1-3-2-4 Posted October 31, 2014 Share Posted October 31, 2014 It goes to the intake however it has something inside the connectionhttp://tapatalk.imageshack.com/v2/14/10/31/3580a2810244d5f20eba28260d150928.jpg Link to comment Share on other sites More sharing options...
BrianEarlSpilner Posted November 1, 2014 Share Posted November 1, 2014 Alright... so the best I can tell it looks like one of the PCV connections that comes off of the stock plastic intake. It looks like it's been cut out of the intake though. Aftermarket inlet tubes (at least the one I have) have 1 less input than the stock one does. I had to take the PCV valve and cut a tee into the PCV hose behind the intake and route it through there. The other connection runs under the intake and into the inlet. Did you cut it out of the inlet or was it like that? Have you just done an inlet install? It gave me a few headaches. Hope this helps get you on the right track. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted November 1, 2014 Author Share Posted November 1, 2014 Yep I found it last night no later then when it started to rain.. I had no issues driving with it not connected it was only when I went to check the oil did I see it. And last owner took out the stock air box Link to comment Share on other sites More sharing options...
baconbits Posted November 1, 2014 Share Posted November 1, 2014 Where does the other end of the hose go to? If it smells like gas, it's the evap canister. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted November 1, 2014 Author Share Posted November 1, 2014 It goes to the intake Link to comment Share on other sites More sharing options...
baconbits Posted November 1, 2014 Share Posted November 1, 2014 So the rubber hose on the end of that 90° connector goes to that blue silicone turbo inlet? Holy hell, that's one hell of a post-MAF air leak. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted November 1, 2014 Author Share Posted November 1, 2014 It's got a valve inside of it, never caused any issues. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted November 1, 2014 Author Share Posted November 1, 2014 http://tapatalk.imageshack.com/v2/14/11/01/838dabefd62c870fc227f194ad7570c2.jpg Link to comment Share on other sites More sharing options...
