Gs Legacy Posted October 31, 2014 Share Posted October 31, 2014 Hello Legacy Forum I am a new member on a mission. I want to transform my 2013 legacy headlights into hawk eye style drls. I have searched online and found this thread. http://legacygt.com/forums/showthread.php/new-2013-headlight-219429.html?t=219429 However, being that all the picture links are dead and all the resources are in Chinese, here I am starting from scratch. The goal. Turn these: http://www.partsvilleauto.com/wp-content/uploads/imported/7/2010-2011-2012-2013-2014-Subaru-Legacy-Outback-Halogen-Headlight-Right-RH-OEM-231244910837-500x334.jpg Into This: http://www.automoblog.net/wp-content/uploads/2014/02/2015-Subaru-Legacy-4.jpg Quality Like: http://fourtitude.com/wp-content/uploads/2012/12/a6-headlight.jpg LEDs I decided to go with the 5050 SMD LED lights that you find on ebay(there goes my quality...lol). The reason being is that they are the most abundant and they don't produce a lot of heat. To be extra "Cautious" I went with the LED's that have the waterproof housing. <---Warning against this if the water proof shield peels off then color changes. Higher quality LEDs Problem: They produce more heat so I would have to worry about dissipating that heat. Also, better quality led's would require me to create my own led board...and I don't got time for that...lol Acrylic medium So I decided to go with acrylic as my medium which light will shine through. I purchased several plexiglass options. 1/8", 1/2" , 1" and stamped. I wanted to use the 1/2" or 1" to make a frosted DRL options. I found that trying to get a uniformed "frosted" look was not so simple. The best way to do this is to use a sand blaster. Being that I don't have a sand blaster and can't afford to get one, I went a different route. Important Specs: In all my attempts I want the light to be uniformed as possible (homogeneous). This means I want it to be evenly spread form any viewing angle as with the Audi style DRL. Essentially you can't tell where the source of light is coming from. Also I want the LEDS are not visible when they are turned off. So I watched this Snells Law video here (Just watch the until 1:06): Watched this: Then read this article(http://www.plexiglas.com/export/sites/plexiglas/.content/medias/downloads/sheet-docs/plexiglas-optical-and-transmission-characteristics.pdf that basically says plexiglass has a critical angle of 42.2 degrees. That being said I took a piece of 1/2" and created the following. 1st Mock Up http://i7.photobucket.com/albums/y260/moreitems4less/2ABFF132-968E-4FE8-8576-B0C3D7CEA1B1_zpsl95izb5f.jpg http://i7.photobucket.com/albums/y260/moreitems4less/5686FB0B-B1F0-46AF-8611-3D3F9600546C_zpsoh92al4h.jpg http://i7.photobucket.com/albums/y260/moreitems4less/0C2B0604-DC5C-424E-8799-4304D4AD2776_zpswvzjidjc.jpg It is coated with nail polish (my wife's) on each end. http://i7.photobucket.com/albums/y260/moreitems4less/AB43670C-87CA-4D4E-922D-359309105DC2_zpsy3bplx1e.jpg http://i7.photobucket.com/albums/y260/moreitems4less/BB9B48A9-C4FD-400F-B8EB-6ACBD7FA0024_zpsjrxgwiio.jpg Light production: http://i7.photobucket.com/albums/y260/moreitems4less/C65ED06E-99F9-47B4-98B2-31422A65D4B3_zpsicamkels.jpg W/Flash http://i7.photobucket.com/albums/y260/moreitems4less/8AF5A8C8-7547-45C5-946F-760398C60A21_zps0ufkjc95.jpg W/Out Flash The lighting out put was so bright and evenly spread that I was in heaven. I really was happy that you could see light at any viewing angle. Though the first mock up was good, the rod was too long. It wouldn't work in our headlights. So, I decided it better make a shorter version using the same specs as my 1st mock up. I made the following. 2nd Mock Up http://i7.photobucket.com/albums/y260/moreitems4less/4B307063-F93C-4DAE-AC2B-6A2C23883BE2_zpsto5gvz2m.jpg http://i7.photobucket.com/albums/y260/moreitems4less/4CE65165-7D32-4ED0-9A38-2839010F7F06_zpsonlqjj74.jpg Light output http://i7.photobucket.com/albums/y260/moreitems4less/DA49D85C-4DD6-43F2-88EE-EFE5603BF30F_zpsbvrshul5.jpg W/Flash http://i7.photobucket.com/albums/y260/moreitems4less/DA2F176B-62CB-4A35-B012-3401AEAEC310_zpszajzioti.jpg W/O Flash As you can tell, its a night and day difference. I was mad!!!! I tried everything to replicate the light output of my first try in a shorter length but I couldn't. So I decide to change it up completely and went with the following: 3rd Mock Up http://i7.photobucket.com/albums/y260/moreitems4less/6762FC92-114D-470B-AE40-BA97B4DCBEB7_zpshusjl26l.jpg http://i7.photobucket.com/albums/y260/moreitems4less/2120B1DE-35FA-485A-990A-201CD30396E7_zpsefctpiwy.jpg http://i7.photobucket.com/albums/y260/moreitems4less/5C0696CA-9195-45B8-AB75-CE1CDA115D41_zps9bfgpui0.jpg This 3rd gave me the best uniformed light and hides the Leds when they are turned off. However, the LEDs must be a certain distance away from the shield. If it isn't then the light source is visible. Also in the picture you notice that my shield is rounded. To get better light output but I will have to flatten that surface. Also the great test advantage is the I will have a flat surface to work with then I install these on the OEM headlights. I can shape them and adjust them appropriately. Light comparison of all three http://i7.photobucket.com/albums/y260/moreitems4less/376FEF2D-080A-41D8-904E-38FC8071447A_zpsmxdhssba.jpg This picture is horrible ( Left: 1st Trial, Left Middle: 2nd Tiral, and Right: 3rd Trial) Whats to come: - Better photos - Setting up a jig to create accurate bends and cuts to match oem headlight specs. - Creating a final mockup - Figuring how to wire multiple inputs to one relay. (Any automotive electricians out the feel free to chime in) - Final installation I do apologize for any grammatical, spelling, scientific errors. I will go over everything and fix them all. Just wanted to get this posted! Link to comment Share on other sites More sharing options...
coppertone Posted October 31, 2014 Share Posted October 31, 2014 Very interesting, will be following this closely.. 2010 2.5GT limited is for sale. Link to comment Share on other sites More sharing options...
GTEASER Posted October 31, 2014 Share Posted October 31, 2014 Wow!! Looks like quite a project. Looking forward to the results. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Gs Legacy Posted November 1, 2014 Author Share Posted November 1, 2014 Wow!! Looks like quite a project. Looking forward to the results. Believe me it is!!! Hopefully it all turns out well! Very interesting, will be following this closely.. Thanks, my first two followers..lol:lol: Link to comment Share on other sites More sharing options...
Gs Legacy Posted November 1, 2014 Author Share Posted November 1, 2014 Bending Form: So today I had the time to make a form for bending the acrylic. The form is no way close to the spec of the oem surround. I just want to it to create sharp/clean bending lines as well as a flat surface for the light to go through. I basically had to make a base and then something to press the acrylic into the base. The base is set at an angle so it could have that "pizza slice" look. I used 1/2" oak to make the base. The "press" is made of oak as well however I had to make it 2/16 of an inch thinner than the jig. Doing this assures that the acrylic has room to move. Also, the press is made longer than the jig. This is so I can slide it (From wide end to small end) to make a tighter sharper form. The Base http://i7.photobucket.com/albums/y260/moreitems4less/107CF4A5-7EE4-4DF1-890A-A8130B79CF9E_zpsg8zfkilo.jpg http://i7.photobucket.com/albums/y260/moreitems4less/0CB246EE-93E1-4303-BFB3-2CD004EAB75C_zpsa8p44gww.jpg The Press http://i7.photobucket.com/albums/y260/moreitems4less/70FC84BE-73A1-4B33-BF97-91E530534F5A_zpsfmbukaux.jpg The Results So after trying out my new press/jig. I found out that heating the acrylic evenly is going to key in getting great results. Right now I am using a butane torch and passing it back and forth on the acrylic. This method works well however you can hear cracking if you missed a spot. I am going to research different ways to heat the acrylic evenly but I will probably just keep using this method until then. Here it is: http://i7.photobucket.com/albums/y260/moreitems4less/120BEB3C-BF37-4FBD-94A4-CCC8AC9076DC_zpsov68btj6.jpg http://i7.photobucket.com/albums/y260/moreitems4less/9C23EBEA-6647-4B62-870B-7CA03484878F_zpsmf1x49vx.jpg http://i7.photobucket.com/albums/y260/moreitems4less/79F19E79-A442-482D-900D-DAA1414F6860_zpsn2xxisqx.jpg Pictures with LED's in it: http://i7.photobucket.com/albums/y260/moreitems4less/639F88A9-AD0B-47F8-B788-46C69E523480_zpssjcl8tuo.jpg With LED on http://i7.photobucket.com/albums/y260/moreitems4less/74B6B545-284C-4309-8354-5051F10282B4_zps1l9xwwgz.jpg 5' away in sunlight http://i7.photobucket.com/albums/y260/moreitems4less/A0A60B97-DB50-4C06-8CEB-E07A00B11420_zps9segq97m.jpg 5' away in shadow http://i7.photobucket.com/albums/y260/moreitems4less/D6E3F6B2-BA50-44B4-AB85-24242A36A840_zps9lok622h.jpg Close up in Sunlight http://i7.photobucket.com/albums/y260/moreitems4less/5EC1F944-B6B8-4396-A3A9-C26F389D1700_zpslk4yybvc.jpg Close up in Shadow http://i7.photobucket.com/albums/y260/moreitems4less/42D38E30-8E03-4C52-BEBF-C09C050AE45B_zpstfx2zkb0.jpg In sunlight http://i7.photobucket.com/albums/y260/moreitems4less/62E0B5D7-40DD-4971-8561-47D84EA0DC49_zpshkop6cyf.jpg http://i7.photobucket.com/albums/y260/moreitems4less/C9D927F8-9356-42E4-BF34-877E11FFAD5B_zpssdsp1ut2.jpg http://i7.photobucket.com/albums/y260/moreitems4less/C9D927F8-9356-42E4-BF34-877E11FFAD5B_zpssdsp1ut2.jpg LEDs Soo....5050 smd leds are not going to cut it in the daylight..... This means I'm going to have to eat my own words and build my own led strip!. The 5050 put out about 15 lumen per led. That definitely can't compete with the sun! So I am thinking about looking into these which produce about 100 lumen per led or these that produce 50 lumen per led. I have never soldered anything before so this is going to be fun!!!! I will try to get these order and installed asap. In the mean time what the heck am I going to do with 3 meters of 5050 smds!!!!! Link to comment Share on other sites More sharing options...
nstg8r Posted November 2, 2014 Share Posted November 2, 2014 Those factory LEDs are much larger and much more powerful than a 5050 Yeah, gonna need something more like this... http://www.samsung.com/global/business/led/lighting/component/high-power/overview/248 Link to comment Share on other sites More sharing options...
Gs Legacy Posted November 3, 2014 Author Share Posted November 3, 2014 Those factory LEDs are much larger and much more powerful than a 5050[/quote Yeah, gonna need something more like this... http://www.samsung.com/global/business/led/lighting/component/high-power/overview/248 You guys are great!!! Got good news...read below!!! Link to comment Share on other sites More sharing options...
Gs Legacy Posted November 3, 2014 Author Share Posted November 3, 2014 The GOOD: Upgrade LEDs So after posting my Sat update. I started to do some research. Much thanks to nstg8r and StevesH6 I started to look into larger and more powerful Leds. Building my own led board would require and electrical engineering degree...lol. It is a lot more complex than soldering led's to a board. Google maps however would end up being my savior...lol! After doing a quick search a found a local LED dealer (The company creates billboard led's). Drove over to the store and ended up meeting the owner. We ended up talking for a while, and she wanted to see the project. The reason is she wants to take her company into the automotive lighting market but wants a representative. Anywhos, I told her what I needed and she guaranteed me that she had something. She said the light would be able to be seen in the daytime. So I purchased 20 pieces went home and I was in love! These lights were great indoors but outdoors was the real test. DSLR in hand I headed outside. It took some quick measurements and found that the top part of the hawk-eye bezel sat about 31" above the ground. So I set my new Leds w/lens setup at the same height at took photos. During this time my neighbor (that one nosey neighbor) come out. He was very curious and asked me why I am taking pictures of "the light". I told him I was working on a project but then instantly got excited! He was able to see the light from across the street in his driveway.(see last picture) So now all I am waiting for is my d2s ballast to come and then I will be doing official install!! I can't wait. Other news: The new LEDs come in different colors. I asks her if they came in amber and if they created a switchback version. She will be looking into it!! For those who don't about know switchback leds. Switchback leds will give one the ability to use the hawk-eye led as a turn signal. The Bad: My only complaint with the new LEDs is that it comes in one standard size/width. Due to this it is going to be difficult to get light to reach the smaller ends of the hawk eye (ends towards the grill) http://i7.photobucket.com/albums/y260/moreitems4less/_MG_7658_zps081dabc2.jpg Indoor Close Up http://i7.photobucket.com/albums/y260/moreitems4less/_MG_7664_zps440eb506.jpg Outdoor Close up (at 31") http://i7.photobucket.com/albums/y260/moreitems4less/_MG_7668_zps579a1710.jpg http://i7.photobucket.com/albums/y260/moreitems4less/_MG_7669_zpsab6b9203.jpg 15 Feet http://i7.photobucket.com/albums/y260/moreitems4less/_MG_7670_zpsfd12eb8a.jpg http://i7.photobucket.com/albums/y260/moreitems4less/_MG_7671_zps0d7ecbc7.jpg 25 Feet http://i7.photobucket.com/albums/y260/moreitems4less/_MG_7672_zps9b917bc1.jpg ~40 feet http://i7.photobucket.com/albums/y260/moreitems4less/_MG_7673_zps0e1eb97c.jpg ~60 feet http://i7.photobucket.com/albums/y260/moreitems4less/_MG_7674_zps7d1c1b55.jpg ~80 feet http://i7.photobucket.com/albums/y260/moreitems4less/_MG_7676_zpsd470f1f4.jpg ~100 feet. (exactly where I was standing talking to my neighbor) http://i7.photobucket.com/albums/y260/moreitems4less/_MG_7678_zps081d2e05.jpg Standing next to the led strip. My neighbor was standing right were the deciduous (evergreen) bush is in the center of the photo. Probably close to 200ft away. Link to comment Share on other sites More sharing options...
Gs Legacy Posted November 3, 2014 Author Share Posted November 3, 2014 Just to be thorough as possible, I took a couple of photos to mimic the 5050 smd shots from earlier. http://i7.photobucket.com/albums/y260/moreitems4less/_MG_7682_zps7eefddc0.jpg http://i7.photobucket.com/albums/y260/moreitems4less/_MG_7683_zps2e26b700.jpg Without lights on http://i7.photobucket.com/albums/y260/moreitems4less/_MG_7688_zps4844ba9b.jpg http://i7.photobucket.com/albums/y260/moreitems4less/_MG_7689_zps0e3dd38d.jpg With lights on Link to comment Share on other sites More sharing options...
Gs Legacy Posted December 4, 2014 Author Share Posted December 4, 2014 I expect to be done with the headlight by dec 19. Stay tuned....http://i7.photobucket.com/albums/y260/moreitems4less/35896D67-A06B-47C7-B95B-6E2C8B359FFB_zpsrkuckwdo.jpg Link to comment Share on other sites More sharing options...
JermTheElf Posted December 4, 2014 Share Posted December 4, 2014 Subbed. Good work so far Link to comment Share on other sites More sharing options...
amidroc Posted December 4, 2014 Share Posted December 4, 2014 looks good. interested to see the outcome Link to comment Share on other sites More sharing options...
Gborja888 Posted December 5, 2014 Share Posted December 5, 2014 Looks cool! Nice work! Looking forward to your final outcome! I'm planning to upgrade mine later in the spring to a more powerful LED from 3W to 6W. Link to comment Share on other sites More sharing options...
Hanger Posted December 5, 2014 Share Posted December 5, 2014 lazy subsribe ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
Gs Legacy Posted December 10, 2014 Author Share Posted December 10, 2014 Just a teaser... http://i7.photobucket.com/albums/y260/moreitems4less/DB649BB3-D6BC-411C-8ADA-726EAE3B4A37_zpstlsxtpwm.jpg http://i7.photobucket.com/albums/y260/moreitems4less/FE1F4DAB-CF12-47F0-8BD0-FD271E1813BC_zpsbidmwz1t.jpg Link to comment Share on other sites More sharing options...
Gs Legacy Posted December 10, 2014 Author Share Posted December 10, 2014 Looks cool! Nice work! Looking forward to your final outcome! I'm planning to upgrade mine later in the spring to a more powerful LED from 3W to 6W. I can't believe you are going to open up those headlights again. Doing that almost made me change my mind! looks good. interested to see the outcome Thanks. It should be soon!!! Subbed. Good work so far Thanks Link to comment Share on other sites More sharing options...
Richievn Posted December 10, 2014 Share Posted December 10, 2014 good Stuff. Considering redoing mine as well. Those cheap led strips burnt down to frequent. I bought the same Stuff like Gbjora888 but the light wasn't that bright so I bided up not installing those. Release show me a better brighter led once you found one. Thanks heap Link to comment Share on other sites More sharing options...
Gs Legacy Posted December 10, 2014 Author Share Posted December 10, 2014 good Stuff. Considering redoing mine as well. Those cheap led strips burnt down to frequent. I bought the same Stuff like Gbjora888 but the light wasn't that bright so I bided up not installing those. Release show me a better brighter led once you found one. Thanks heap So I must know. How did you do your headlights. It looks like you cut the bezel and then used a white plexiglasss sheet. Am I correct? Fitment is my major problem right now since my leds are pretty big. LMK what you are using. LOVE your lights. Also, how'd you do the switchback/turn signal wiring? Link to comment Share on other sites More sharing options...
Richievn Posted December 10, 2014 Share Posted December 10, 2014 So I must know. How did you do your headlights. It looks like you cut the bezel and then used a white plexiglasss sheet. Am I correct? Fitment is my major problem right now since my leds are pretty big. LMK what you are using. LOVE your lights. Also' date=' how'd you do the switchback/turn signal wiring?[/quote'] Yeah I gotta cut the bezel (and broke it finally) and glued a cut flexiglass into it. I thought of acrylic before but could find a decent one thats bendable. Mind you that the space behind is very tight and I could not slide another acrylic rod into it. Good try by the way. The wiring is not difficult as the led strip came with 2 colour themselves and I only tap into the respective wires. Looking at your work and preparing mine .. ;) Link to comment Share on other sites More sharing options...
Gs Legacy Posted December 12, 2014 Author Share Posted December 12, 2014 Yeah I gotta cut the bezel (and broke it finally) and glued a cut flexiglass into it. I thought of acrylic before but could find a decent one thats bendable. Mind you that the space behind is very tight and I could not slide another acrylic rod into it. Good try by the way. The wiring is not difficult as the led strip came with 2 colour themselves and I only tap into the respective wires. Looking at your work and preparing mine .. ;) 1st: Hats off to you for being able to put anything in that space. 2nd:The Led's that I'm using only comes in one color. I would have to use two different Led systems.So, for me to use the actual use mine as turn signals it will require some modification. I would want to the white light to turn off while the amber is working. For now its not a big deal. Just had a crazy thought that would have made this whole thing simpler. It would be easier/look nicer if you used a hollow plexiglas tube. Like this one (http://www.tapplastics.com/product/plastics/plastic_rods_tubes_shapes/clear_acrylic_tubes/141). All you would have to do then is cut it in half, add lines (like 2015 legacy pics), place lights behind it, and you are done!!! Link to comment Share on other sites More sharing options...
Gs Legacy Posted December 12, 2014 Author Share Posted December 12, 2014 http://i7.photobucket.com/albums/y260/moreitems4less/9F4E9EF4-B2EB-40EE-97C5-1795BDEC7CE2_zpsf6tcucgq.jpg http://i7.photobucket.com/albums/y260/moreitems4less/339331FF-2048-4D82-8755-8168FA557464_zpsh41fr6dq.jpg http://i7.photobucket.com/albums/y260/moreitems4less/12153C70-9238-4398-9013-E3654153F0D1_zpsc8gnyfnw.jpg Latest update Link to comment Share on other sites More sharing options...
Andy_Mac Posted December 12, 2014 Share Posted December 12, 2014 Good effort man, keen to see how this turns out once fitted 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
Gborja888 Posted December 12, 2014 Share Posted December 12, 2014 Great work! Make sure you don't overextend it and try to test putting the glass cover every now and then. I remember the gap in between the glass cover and the hawk eye or eyebrow is really tight. Link to comment Share on other sites More sharing options...
Gs Legacy Posted December 20, 2014 Author Share Posted December 20, 2014 Good effort man, keen to see how this turns out once fitted Thanks Great work! Make sure you don't overextend it and try to test putting the glass cover every now and then. I remember the gap in between the glass cover and the hawk eye or eyebrow is really tight. I definitely checked and everything turned out great! Tons of space. Unfortunately I got called into work today so I won't be able to finish up till next week. Link to comment Share on other sites More sharing options...
efren5483 Posted January 6, 2015 Share Posted January 6, 2015 Did you ever finish? How's it look? Link to comment Share on other sites More sharing options...
