volcomst0ne24 Posted September 10, 2005 Share Posted September 10, 2005 does it work, does it make ANY sense? Link to comment Share on other sites More sharing options...
SUBE555 Posted September 10, 2005 Share Posted September 10, 2005 A blow-off valve releases excess pressure when you shift or let off during acceleration. It's only for forced induction engines such as turbocharged or supercharged. For reference, there are a few types of valves that do this function. They can either vent completely to atmostphere, partially to atmosphere, or complete recirculation as the Subaru stock recirculation system ducts excess pressure back into the turbo inlet pipe just before the compressor inlet. Link to comment Share on other sites More sharing options...
foghat Posted September 10, 2005 Share Posted September 10, 2005 Not true, it will work but only if you use sealed muffler bearings and dot 5 blinker fluid. Link to comment Share on other sites More sharing options...
meier motor sports Posted September 10, 2005 Share Posted September 10, 2005 Not true, it will work but only if you use sealed muffler bearings and dot 5 blinker fluid. the man speaks the truth! Link to comment Share on other sites More sharing options...
meier motor sports Posted September 10, 2005 Share Posted September 10, 2005 http://www.kalecoauto.com/fluids.htm buy your blinker fluid here Link to comment Share on other sites More sharing options...
PhilT Posted September 10, 2005 Share Posted September 10, 2005 http://www.kalecoauto.com/fluids.htm buy your blinker fluid here Excellent site, great products, cheap prices. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
agctr Posted September 10, 2005 Share Posted September 10, 2005 Or you could always get the BOV CD for yr ride, just put the speaker under the hood.... Dont laugh, its been done, havent seen it myself but I have read about it.... some ppl have way too much time on their hands lol. Ada///M. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted September 10, 2005 Share Posted September 10, 2005 Just put a whistle on your exahsut pipe if you want some noise. Link to comment Share on other sites More sharing options...
volcomst0ne24 Posted September 10, 2005 Author Share Posted September 10, 2005 so basically, no bov for a non turbo? Link to comment Share on other sites More sharing options...
Wolf Howl Posted September 10, 2005 Share Posted September 10, 2005 http://www.sunamiturbo.com/ That should take care of it. Link to comment Share on other sites More sharing options...
jagcars26 Posted September 10, 2005 Share Posted September 10, 2005 so basically, no bov for a non turbo? Is that a trick question??? Rudy Link to comment Share on other sites More sharing options...
SUBE555 Posted September 10, 2005 Share Posted September 10, 2005 I answered that at the top. No, no 'real' blow-off or bypass valve on non-turbo cars. Link to comment Share on other sites More sharing options...
ams Posted September 10, 2005 Share Posted September 10, 2005 does it work, does it make ANY sense? ROTFL :lol::lol::lol: Link to comment Share on other sites More sharing options...
Xenonk Posted September 10, 2005 Share Posted September 10, 2005 does it work, does it make ANY sense? For all the guys that are missing the real answer and all the guys who are making fun of your intellect, I will give you a straight answer and educate you. You can have a BOV with a turbo, a supercharger, or any other type of set up that create pressure more than 14.7 psi (normal atmospheric pressure at sea level). When a turbo car makes 14 psi of boost, it's "boosting" the atmospheric pressure to simulate 28.7 psi. The BOV is designed to release pressure at a certain psi to prevent the turbo or supercharger (or any type of compressor) from backpressure. So in your case, a car without a supercharger, turbo, or any other compressor type set up does not need a BOV because it's not making additional boost to break the compressor (you can not break something if you never had a compressor in the car in the first place). I have heard some really silly people weld a BOV on the exhuast track and block up the exhaust (dumb to begin with since you want a very clear exhaust flow to make power) but they just wanted a whistling or blow-off sound. The only place where the exhaust vents out is through the BOV. If you want a BOV for a normal aspirated car, you get yourself a speaker and a silly amp that plays the BOV sound which hooks up to your throttle cable and every time you let off the gas, the sound goes off. Please use http://www.howstuffworks.com for more info and learn about how turbo works, how superchargers work and all that sort. Edit: 14.7 psi = 1 atm, my bad. Keefe Link to comment Share on other sites More sharing options...
volcomst0ne24 Posted September 10, 2005 Author Share Posted September 10, 2005 thanks... Link to comment Share on other sites More sharing options...
foghat Posted September 10, 2005 Share Posted September 10, 2005 I sure hope that they didnt ship out my blinker fluid before I can cancel the order, I think those a-holes might have ripped me off!! Link to comment Share on other sites More sharing options...
first5.0 Posted September 11, 2005 Share Posted September 11, 2005 Just put a whistle on your exahsut pipe if you want some noise. "It's like, woooo WOOOOO!!" Link to comment Share on other sites More sharing options...
team23jordan Posted September 11, 2005 Share Posted September 11, 2005 ricer!!!! Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
Gire Posted September 11, 2005 Share Posted September 11, 2005 "It's like, woooo WOOOOO!!" That whistle-tip internet clip was a classic!!! What was that crack-head's name who got "interviewed"? Wasn't his name Bubba Rub? "whooooooo WHOOOOOOOO!!!!":lol: :lol: :lol: Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted September 11, 2005 Share Posted September 11, 2005 Imagine that. Your 15 minutes of fame are from going Woo Woo into a camera. Link to comment Share on other sites More sharing options...
a.spider Posted September 12, 2005 Share Posted September 12, 2005 "You can have a BOV with a turbo, a supercharger, or any other type of set up that create pressure more than 14.3 psi (normal atmospheric pressure at sea level)." AARRRGGGHHHH!!!! QUICK!!! SLOW DOWN AND ROLL DOWN THE WINDOWS!!! DO IT BEFORE YOU PASS OUT FROM CEREBRAL ANOXIA!!!! I am not familiar with the conditions on your planet, but here on Earth 1 atmosphere at sea level is defined to be exactly 101.325 kilopascals, or approximately 14.6959 psia. The latter value is commonly abbreviated as 14.7 lbf/in^2. For sufficiently small values of 7 a 3 may be substituted, but that alteration should NEVER be shown to a mathematician or a physicist or you risk being pummeled. We now return you to your regular scheduled program. Link to comment Share on other sites More sharing options...
GBY Posted September 12, 2005 Share Posted September 12, 2005 I think the question has been answered and we are all cool on this. Cheers Dave. Link to comment Share on other sites More sharing options...
