StickyBL6 Posted September 30, 2014 Share Posted September 30, 2014 so i keep hearing about the 2007 legacy gt motors have a problem with a leaking head gasket? dont know how true but i bought the car from a lot about a week ago (come wednesday) and when i went to lunch tonight i noticed my car was smoking.. so i stopped in the parking lot to look at it and noticed it was leaking. touched it and noticed it was anitfreeze got underneath it and looked and noticed this part has a small crack or chip in it.. can anyone help me and tell me what this is and what it maybe? im sorry the photos suck but im at work and i dont have low pro jack to put her up on Link to comment Share on other sites More sharing options...
Brian3676 Posted September 30, 2014 Share Posted September 30, 2014 I would guess radiator is leaking. Common on the LGT. Before buying a new one though check to make sure all the hoses and radiator caps are good and tight. Link to comment Share on other sites More sharing options...
apexi Posted September 30, 2014 Share Posted September 30, 2014 I can't see the crack/chip you're referring to, but to me it looks like the leak is coming down from where I circled in red. Is that hose clamp tight, and does it look like the leak might be coming from that hose? Link to comment Share on other sites More sharing options...
StickyBL6 Posted October 1, 2014 Author Share Posted October 1, 2014 i thought it might be that hose but i checked this morning and no it wasnt. i had it towed to the dealer lot where i bought it and they towed it to the shop. the shop said it was my water pump for sure and possibly my timing belt.. so since i just bought the car and they want to charge me 250$(i know its not alot for the job) im gonna contact my lawyer and see what rights i have since ive only owned the car for 6 days and havent even gone 500 miles. however @apexi I circled the spot i thought was chipped/cracked in yellow.. it was leaking from there when i pulled over to check why she was steaming/smoking. Btw thanks for the help everyone Link to comment Share on other sites More sharing options...
AZP Installs Posted October 2, 2014 Share Posted October 2, 2014 Did you have a compression test done when you bought it? I would worry about that more than the WP/Timing belt issue. Also your lawyer is likely to charge you more than $250 for that advice, lawyers run about $300-400/hr! It is also considered maintenance so the dealer can likely not do anything and still be fine. -Mike Paisan http://www.pbase.com/paisan/image/153798190.jpg Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
DonnyJagaru Posted October 3, 2014 Share Posted October 3, 2014 Surely there's more protection for consumers in California than this? Heck, here in Ontario we have legislation that protects used car buyers for 30 days that covers this kind of thing. Link to comment Share on other sites More sharing options...
StickyBL6 Posted October 3, 2014 Author Share Posted October 3, 2014 yea we have a protection period of one month or 1000 miles from what ive been told. i however have not done a compression test. would that be able to be done at the local dyno shop? Link to comment Share on other sites More sharing options...
apexi Posted October 3, 2014 Share Posted October 3, 2014 Without knowing the details of the dyno shop, I want to say yes they should be able to do a compression test if they also do maintenance and aren't strictly a dyno facility. Link to comment Share on other sites More sharing options...
AZP Installs Posted October 5, 2014 Share Posted October 5, 2014 You should be able to get it done at just about any shop that does maintenance but I would find a place that specifically deals with subies because it can be a bit tricky. -Mike Paisan http://www.pbase.com/paisan/image/153798190.jpg Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
Max Capacity Posted October 9, 2014 Share Posted October 9, 2014 I have no idea how a timing belt can be leaking coolant. But what do I know... When my water pump bearing was leaking it dripped onto the exhaust heat shield. No staining on the timing belt cover, that I remember. Never took a picture but it was obvious what it was. That hose may have a pin hole in the bottom of it, I agree with apexi, the white trail gives a clue. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
