abarnesDLGT Posted September 19, 2014 Share Posted September 19, 2014 i have a pair of BMW rims (with adapters ) that are 235/45 R17" is it safe to put these on my LGT seeing how they are quit a bit wider than the stock rubber. i just don't want anything to go wrong…. thoughts? Link to comment Share on other sites More sharing options...
vagabond Posted September 19, 2014 Share Posted September 19, 2014 I have that size on my car now. Link to comment Share on other sites More sharing options...
Mike07LGT Posted September 19, 2014 Share Posted September 19, 2014 i have a pair of BMW rims (with adapters ) that are 235/45 R17" is it safe to put these on my LGT seeing how they are quit a bit wider than the stock rubber. i just don't want anything to go wrong…. thoughts? A pair?? Are you only planning on putting 2 on?? 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
abarnesDLGT Posted September 19, 2014 Author Share Posted September 19, 2014 Oh my bad I ment to say a set of 4 ; just wanted to make sure everything will fit before I commit Link to comment Share on other sites More sharing options...
JBear Posted September 19, 2014 Share Posted September 19, 2014 You're using wider tires for winter? 0_o Link to comment Share on other sites More sharing options...
abarnesDLGT Posted September 21, 2014 Author Share Posted September 21, 2014 its just what i have available for free Link to comment Share on other sites More sharing options...
Max Capacity Posted September 22, 2014 Share Posted September 22, 2014 You do live in a place that gets snow...you do know that...right ? These must be All-season tires with lots of tread on them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
abarnesDLGT Posted September 23, 2014 Author Share Posted September 23, 2014 No they are almost new studded hancooks Link to comment Share on other sites More sharing options...
Max Capacity Posted September 23, 2014 Share Posted September 23, 2014 Oh, see now we have more info. You should be fine. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
abarnesDLGT Posted September 24, 2014 Author Share Posted September 24, 2014 Haha sorry about the lack of info, but that's all I needed to know, obviously to save myself from mounting them just to have to take them off due to size Link to comment Share on other sites More sharing options...
abarnesDLGT Posted January 6, 2015 Author Share Posted January 6, 2015 The shop wouldn't mount them and said they were too wide , do they just say that because of liability ? Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted January 6, 2015 Share Posted January 6, 2015 So they didn't check if they would rub? Just said too wide... How about too lazy... 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
abarnesDLGT Posted January 7, 2015 Author Share Posted January 7, 2015 I agree, I'll try calling another shop Link to comment Share on other sites More sharing options...
Max Capacity Posted January 7, 2015 Share Posted January 7, 2015 Steamboat, I hope you ski ? Wait, you said, i have a pair of BMW rims (with adapters ) that are 235/45 R17 Do your have a pair or a set of rims with tires mounted ? Why don't you just have the tires mounted on the GT wheels ? That would be the way I'd do it. If your going to add spacers/adaptors, plus the off set of the BMW wheel...I can see why the shop said no. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
abarnesDLGT Posted January 8, 2015 Author Share Posted January 8, 2015 The gt wheels I have are 215. I didn't think you could mount those rubber on there , I have a full set of 4 rims with tires on them and the adapters add another inch in stance on either side so I thought they would be fine and wouldn't rub. But I solved my problem. I bought some pretty cheap 16" impreza rims that have brand new snow tires on it....... I have stock breaks so the wheels should clear then ..... I think? And yes I ski a lot haha Link to comment Share on other sites More sharing options...
Max Capacity Posted January 8, 2015 Share Posted January 8, 2015 16's will not fit over stock GT brakes. The 235's can be mounted on the stock GT wheels. I had a great time a Steamboat a few years back. Great hill. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
turboboost Posted January 8, 2015 Share Posted January 8, 2015 16's won't clear LGT brakes. 235's will fit fine on stock LGT wheels. Might be a little meaty, but it'll fit fine. You shouldn't have any clearance issues either, since you wouldn't be running adapters. Link to comment Share on other sites More sharing options...
scontivt Posted January 8, 2015 Share Posted January 8, 2015 They will fit, but good luck getting them back off... three guys, a lot of cussing and a ruined tire resulted in removing 4 from my stock 2005 LGT wheels... good thing the tires were already toasted from potholes. Also, you should know that that width will make you feel like you are floating on top of the snow. Link to comment Share on other sites More sharing options...
abarnesDLGT Posted January 9, 2015 Author Share Posted January 9, 2015 I didn't realize you could but 235 tires on a smaller width rim Link to comment Share on other sites More sharing options...
06lgtspecb Posted January 9, 2015 Share Posted January 9, 2015 I didn't realize you could but 235 tires on a smaller width rim You can to a point, there will be a max you can fit. It will also make the tire taller on the rim compared to if it were on a wider rim. Link to comment Share on other sites More sharing options...
