chuckyD Posted September 16, 2014 Share Posted September 16, 2014 Hello, I just bought an 06 Spec.b a few weeks ago and found out it needs some work (190k miles). I need to replace all the bushings basically. So Im thinking about just doing everything while I'm under there. Should i go with all whiteline? I'm just daily driving. Here's what i need. Any suggestions on where to get everything for a good price? I need my entire LCA rebuilt. ball joints anti-sway link bushings sway bushings rear diff mounts rear lateral arms Thanks in advance. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 16, 2014 Share Posted September 16, 2014 Contact Mike at www.AZPinstalls.com he can get you what you need. If your in NJ your close to him and his shop. He helps out here for free, so I like to support him. I've bought $$$$ from him. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
chuckyD Posted September 16, 2014 Author Share Posted September 16, 2014 Thanks!! Link to comment Share on other sites More sharing options...
CapnJack Posted September 17, 2014 Share Posted September 17, 2014 I'm doing all mine right now. I bought mine from Mike at Infamous. He can also install them if you are on the west coast. I'm using all Whiteline. The fitment is perfect and quality is top notch. Link to comment Share on other sites More sharing options...
