RuskiTrombone Posted September 7, 2005 Share Posted September 7, 2005 Like the title says, is there any difference between the aftermarket springs for the wagon and sedan? Link to comment Share on other sites More sharing options...
Xenonk Posted September 7, 2005 Share Posted September 7, 2005 I believe so as the STi Pink Springs come in many flavors for the Wagon, Sedan, 2.5i, GT, 3.0R, OBXT, etc. Keefe Link to comment Share on other sites More sharing options...
Beanboy Posted September 7, 2005 Share Posted September 7, 2005 In the OEM realm, the rear springs are different. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
Drakuun Posted September 7, 2005 Share Posted September 7, 2005 I'd assume that the Wagon springs are stiffer being with the extra weight and cargo capacity of the Wagon v. Sedan? Link to comment Share on other sites More sharing options...
PGT Posted September 7, 2005 Share Posted September 7, 2005 front springs are the same for sedan to wagon. The rears get a different P/N to accomodate the slight increase in weight and cargo load. Link to comment Share on other sites More sharing options...
Xenonk Posted September 7, 2005 Share Posted September 7, 2005 do a search in the suspension forums, I think I posted the differences in the spring rates for just the STi pink springs and their P/Ns. Keefe Link to comment Share on other sites More sharing options...
PGT Posted September 7, 2005 Share Posted September 7, 2005 http://www.legacygt.com/forums/attachment.php?attachmentid=4643 Link to comment Share on other sites More sharing options...
RuskiTrombone Posted September 7, 2005 Author Share Posted September 7, 2005 So what would happen if you put wagon springs on a sedan? Would the rear look a bit higher and not settle as much as the front or would it just be a bit stiffer. Link to comment Share on other sites More sharing options...
Xenonk Posted September 7, 2005 Share Posted September 7, 2005 moved to suspension forums yay- I got my super powers back! Keefe Link to comment Share on other sites More sharing options...
PGT Posted September 7, 2005 Share Posted September 7, 2005 So what would happen if you put wagon springs on a sedan? Would the rear look a bit higher and not settle as much as the front or would it just be a bit stiffer. the back would sit a bit higher. Not a bad stance...better than the other way around. Link to comment Share on other sites More sharing options...
RuskiTrombone Posted September 7, 2005 Author Share Posted September 7, 2005 That's how my GTS celica sat. It was a little bit higher in the back instead of just all even. Link to comment Share on other sites More sharing options...
Xenonk Posted September 7, 2005 Share Posted September 7, 2005 the back would sit a bit higher. Not a bad stance...better than the other way around. My car is the other way around with the front being higher than the rear (gotta love coilovers and ride height adjustments).. I think the spring rates have little difference (1kg at most which is like a 56 lbs more "spring" to it). But the length of the spring might be actually a lot taller on the wagon than the sedan. PGT can verify of where the mounting points are on the wagon, but for the sedan the mounting points for the rear is located on the base of the trunk floor.. if the wagons are higher up, then it's possible that the shocks are longer to accomodate the mounting point and the spring will be proportionally just as long/tall. Keefe Link to comment Share on other sites More sharing options...
PGT Posted September 7, 2005 Share Posted September 7, 2005 wagons are the same spot. Having done suspension swaps on my car and a few sedans.....the pieces look the same. Given that aftermarket springs are the same for wagons and sedans (for the most part), this makes sense. Link to comment Share on other sites More sharing options...
Xenonk Posted September 7, 2005 Share Posted September 7, 2005 Sounds good, then it just might be a spring rate difference if anything. Keefe Link to comment Share on other sites More sharing options...
PGT Posted September 7, 2005 Share Posted September 7, 2005 I'd even go so far as to say that if you plan to put a sub box in, the wagon springs might do you some good on the sedan. A decent sub, enclosure and amp weighs about as much more as the wagon (50lbs?) Link to comment Share on other sites More sharing options...
RuskiTrombone Posted September 7, 2005 Author Share Posted September 7, 2005 Very good responses guys. Thanks for the info. Link to comment Share on other sites More sharing options...
rc0032 Posted September 7, 2005 Share Posted September 7, 2005 So what would happen if you put wagon springs on a sedan? Would the rear look a bit higher and not settle as much as the front or would it just be a bit stiffer.I'm running this for 10K miles now with no issues. I found the wagon springs cheap and went for it Link to comment Share on other sites More sharing options...
PGT Posted September 7, 2005 Share Posted September 7, 2005 I'm running this for 10K miles now with no issues. I found the wagon springs cheap and went for it Kevin? Link to comment Share on other sites More sharing options...
rc0032 Posted September 7, 2005 Share Posted September 7, 2005 Kevin?http://images.nasioc.com/forums/images/smilies/banana.gif Link to comment Share on other sites More sharing options...
