garygbnj Posted August 29, 2014 Share Posted August 29, 2014 Since new was not the smoothest trans I have ever driven. Notchyness seems to have gotten worse. Using the suggested redline, motul 300 combo for trans fluid. It did stop the 4th gear grind. Is there anything I can do to make the trans "less notchy"? thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted August 29, 2014 Share Posted August 29, 2014 Replace shifter bushings. Just google your town, your minutes from AZPinstalls shop They are a place you going to want to get to know. Contact Mike. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted August 29, 2014 Share Posted August 29, 2014 this may help too. http://legacygt.com/forums/showthread.php/shifter-bushingii-229665.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
