frapjap Posted August 8, 2014 Share Posted August 8, 2014 I've searched all over this forum and the internet in general but cannot find a list of all of the grounds located in the engine bay on my 2007 Legacy. The ones I've found are: drivers strut tower passenger head to chassis drivers head to chassis starter pair at the front of the passengers side intake runner Am I missing one or more? Thank you all for the help with a trivial question Link to comment Share on other sites More sharing options...
jeffy2.5xt Posted August 10, 2014 Share Posted August 10, 2014 no input from me, but why do you ask? are you going to do an upgraded setup of some sort? just curious. Link to comment Share on other sites More sharing options...
frapjap Posted August 11, 2014 Author Share Posted August 11, 2014 I have a no start, no CEL condition after R&R of head gaskets. Wanted to be sure I wasn't missing anything small and simple. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 11, 2014 Share Posted August 11, 2014 Two ground wires on the bracket in front of the master brake cylinder. Make sure they are clean before you attach them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
frapjap Posted August 11, 2014 Author Share Posted August 11, 2014 Definitely haven't noticed them before and will take a look for those today. Thank you very much! Link to comment Share on other sites More sharing options...
Max Capacity Posted August 11, 2014 Share Posted August 11, 2014 There is a thread about replacing and making up the two lower grounds off the heads. I thought I had a picture of the rear grounds, but couldn't find earlier this AM. I now I have it in my file on my home PC. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
frapjap Posted August 11, 2014 Author Share Posted August 11, 2014 I replaced the the grounds on the heads when the heads went back in. They were corroded, broken, and not doing anything of value. If you find it, I'm looking forwards to the photo. Link to comment Share on other sites More sharing options...
discojon Posted August 11, 2014 Share Posted August 11, 2014 Signal wire to starter attached? That will cause your issues... Link to comment Share on other sites More sharing options...
frapjap Posted August 11, 2014 Author Share Posted August 11, 2014 Signal wire to the starter is attached, and I am able to jump the starter with the battery. However, it won't turn over since there is no fuel. Starter wire gets 12v. Max Capacity- I looked for those grounds but did not see them. http://i1287.photobucket.com/albums/a635/frapcap/unnamed_zps5373e5a7.jpg Top view of master cylinder. http://i1287.photobucket.com/albums/a635/frapcap/unnamed3_zpsb2d44131.jpg Ground on the front of the strut tower, behind the fuse box. http://i1287.photobucket.com/albums/a635/frapcap/unnamed2_zps268c5ab8.jpg View looking at the side of the strut tower at the only bracket near the master cylinder. http://i1287.photobucket.com/albums/a635/frapcap/unnamed4_zps32ff007e.jpg Another view of the same area, elevated. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 12, 2014 Share Posted August 12, 2014 http://i185.photobucket.com/albums/x40/92Si/DSCN4778.jpg On the very left side, left of the water tubes for the heater core, you'll see two bolts, those are the grounds. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
frapjap Posted August 13, 2014 Author Share Posted August 13, 2014 Went to take a look for those grounds and the bracket. What year is that engine? I dont have the bracket or any grounding cables anywhere near that head on my 2007 2.5i, n/a engine. The intake runners on the engine you posted are plastic. Mine are metal. http://i1287.photobucket.com/albums/a635/frapcap/photo1_zpsb4324bd5.jpg Photo of the drivers side head by the heater core hoses. The only pair of grounding cables I have on my engine are in the front of the intake. http://i1287.photobucket.com/albums/a635/frapcap/photo3_zpsb9c730f9.jpg Link to comment Share on other sites More sharing options...
Max Capacity Posted August 13, 2014 Share Posted August 13, 2014 Oh you have a 2.5i sorry. that's my 05 GT. Look in the service manual http://people.csail.mit.edu/ilh/vacation/ 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
frapjap Posted August 13, 2014 Author Share Posted August 13, 2014 Thank you for the link. Its missing the 2007 model, but I've been working off the 2008 FSM for a few weeks. Sure am glad someone saw fit to upload that to the web. I'm really hating this effin' car. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 13, 2014 Share Posted August 13, 2014 The 07 should be the same as a 05-06 for the most part. Or like you have been doing the 08 might have the 07. I have never looked. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
