Andy_Mac Posted August 2, 2014 Share Posted August 2, 2014 I've got a 2006 JDM gt spec b Have been playing around with romraider and logging for a while now and that all works perfectly but went to try pull the rom from the ecu in ecuflash, as i would like to get it etuned at some point, and it just doesn't work. Could be something simple that i'm doing wrong but i'm rather stuck on what is wrong. Any thoughts on what vehicle type should be used? and the definition file for that ecu is in the metadata file so its not that it doesn't know it. Using the latest version of ecuflash CAL ID: A2UG000K ECU ID: 4B04785007 http://i1149.photobucket.com/albums/o594/andy_mac1/ecuflash_zps031cdc3a.png any help would be amazing 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
chimera Posted August 4, 2014 Share Posted August 4, 2014 Hey mate, whereabouts in nzl are ya? You can borrow my tactrix cable and notebook to compare/test if you like. I'm im akl. Link to comment Share on other sites More sharing options...
covertrussian Posted August 4, 2014 Share Posted August 4, 2014 Dumb question, but did you connect the green test connectors? 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
chimera Posted August 4, 2014 Share Posted August 4, 2014 ^ you don't need too - in fact, in that model you shouldn't Link to comment Share on other sites More sharing options...
Andy_Mac Posted August 4, 2014 Author Share Posted August 4, 2014 I'm down in tga. Got a tactrix and all that already You on clubsub? 4th gens are starting to be a bit more popular over there Ah yes i did connect the green connectors. Got it working now, someone over on romraider.com said to try subarucan for the vehicle type which worked. Had green connectors connected. Stupidly assumed they weren't can based systems. 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
