boattlebot Posted July 13, 2014 Author Share Posted July 13, 2014 Im actualy moving from pa to ny at the end of the month lwhen I graduate school lol. But if the 95 ej22e is obd2 then yea shouldent matter, one more thing should I use the95 's pcm or use my 96 pcm? Link to comment Share on other sites More sharing options...
johnegg Posted July 13, 2014 Share Posted July 13, 2014 the 95 ej22 will swap into the 96 car and run on the 96 ECU. do not swap the computer. but the 95 ej22 has dual exhaust ports and the 96 is single port. you will need the exhaust y-pipe that is attached the 95 engine. or any dual port exhaust y-pipe from 93 -99, legacy, impreza, outback or forester. ej22 engines 96 - 98 are plug and play. they all have the same single exhaust ports. the 96 ej22 is a non-interference engine 97 - 98 are interference. look for good used parts of all kinds at: www.car-part.com sort by zip code to see what is close. but it sounds like you have found an engine . is the 95 ej22 from an auto trans car? they have EGR, you need EGR. especially if you are moving to NY. Link to comment Share on other sites More sharing options...
boattlebot Posted July 13, 2014 Author Share Posted July 13, 2014 Doing a manual swap fron a 95wagon into my 96 so I have all the little things minus a new shift knuckel and shift knob. I figure its a good deal and I want to do a manual swap anyways so might as well take the opertunity since I need a motor. But since I wont have egr anymore becuase manual should I still stick with my 96 auto trans pcm? Link to comment Share on other sites More sharing options...
Zues Marine Posted July 13, 2014 Share Posted July 13, 2014 you'll technically be alright by just grounding the AT/MT iD Pin Link to comment Share on other sites More sharing options...
boattlebot Posted July 13, 2014 Author Share Posted July 13, 2014 Sweet, thanks for the info. I got a feelin this is gunna turn into a build thread Link to comment Share on other sites More sharing options...
boattlebot Posted July 14, 2014 Author Share Posted July 14, 2014 well i no longer have a place to work on my car.....with the egr, if i use my 96 intake manifold and just use the 95 block, would that work? (for leaving it auto) ill pull the drivetrain out and do the stick swap at a later date. also anyone near pottstown king of prussia or exton pa got a spot i could do a motor swap? Link to comment Share on other sites More sharing options...
worknlikeadog Posted July 14, 2014 Share Posted July 14, 2014 I've see people do it in monthly rental units for storage Link to comment Share on other sites More sharing options...
boattlebot Posted July 14, 2014 Author Share Posted July 14, 2014 thats a good idea, but. looks like my subies done for. i cant fix it, its not worth it for starters and he keeps adding to the list of parts it needs. with my timeframe it looks like im getin rid of my subie :icon_cry: so anyone want a 96 bk with a blown motor? minimal rust... Link to comment Share on other sites More sharing options...
johnegg Posted July 15, 2014 Share Posted July 15, 2014 with the egr, if i use my 96 intake manifold and just use the 95 block, would that work? link : Using a NON-EGR engine in Subaru with EGR - Submit a Tip or Mod to the USRM - Ultimate Subaru Message Board Link to comment Share on other sites More sharing options...
boattlebot Posted July 15, 2014 Author Share Posted July 15, 2014 Thanks for the link but without a place to work on my subie thiers nothing I can do.... tomarro im going car shoping, and its not even my call anymore my grandmas making it and its her money her call and she decided get rid of the subie Link to comment Share on other sites More sharing options...
Zues Marine Posted July 15, 2014 Share Posted July 15, 2014 i would so buy that if you were not that far away Link to comment Share on other sites More sharing options...
twisty Posted July 15, 2014 Share Posted July 15, 2014 ya i would buy it if i were on the same side of the continent. Link to comment Share on other sites More sharing options...
boattlebot Posted July 18, 2014 Author Share Posted July 18, 2014 Well the poor subies got a date with the junk yard tomarrow, im gunna miss the thing. But a 2001 mustang 5spd definitely makes me a little happier Link to comment Share on other sites More sharing options...
Stevo F Posted July 20, 2014 Share Posted July 20, 2014 Good luck with the Stang- we'll miss you in the Subie world. Of course just this year I've said goodbye to the Nissan Hardbody truck and 9th generation Corolla forums as those vehicles left here when I purchased my two Imprezas. Link to comment Share on other sites More sharing options...
