garygbnj Posted July 7, 2014 Share Posted July 7, 2014 Special S and redline gear oil. It stopped the 4th gear grind. Shifting is notchy. 176 k miles. Any remedies? The trans was never the smoothest I have driven. Sometimes on fast acceleration will miss a shift, sometimes difficult to go into reverse-dbl clutch to engage. Anything to allow smooth fast shifts? Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 23, 2014 Share Posted July 23, 2014 no fix only band-aids You can try a different fluid mix but in the end youll need to replace the wearing/worn parts in the gearbox Link to comment Share on other sites More sharing options...
caramall2 Posted July 23, 2014 Share Posted July 23, 2014 Maybe a syncro going out. Had that happen on mine (and it happened at like 25k miles!). Link to comment Share on other sites More sharing options...
