firehawk618 Posted June 15, 2014 Share Posted June 15, 2014 Hello, thanks for any input you are willing to give me. I recently removed the cobb ap tune I had in my car as I am going to go open source. I am waiting for injectors to come but until then I may need to drive the car to work and back, depending on weather. What I would like to do is turn my boost down to ~7psi to keep things safe until I can get the new injectors and a base tune going. Mods are in my sig. I have dumped my stock bin file. I was going to open romraider and change the following: Let me know if I am going about this wrong. Target boost A and B. Go through and lower anything above 7. Change it to all be 7 This would limit my car to ~7psi under all circumstances wouldn't it? Is there a better way to keep things very safe until I get my injectors / new tune? I understand my turbo is pretty much like stock so it's not like I'm playing with grenades but still I would like to be safe. Thanks in advance~! 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
cryo Posted June 15, 2014 Share Posted June 15, 2014 That would not reduce boost as you think it would. There are a few tables that would need edited as well. Best bet if your not sure about how to edit the tune is to loop the waste gate and turbo nipple so you will be mechanically limited to waste gate boost. Hope that helps. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
firehawk618 Posted June 15, 2014 Author Share Posted June 15, 2014 That would not reduce boost as you think it would. There are a few tables that would need edited as well. Best bet if your not sure about how to edit the tune is to loop the waste gate and turbo nipple so you will be mechanically limited to waste gate boost. Hope that helps. Dave Yes it does. Thanks. 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted June 15, 2014 Share Posted June 15, 2014 Temp map sent Chad. Should be safe until your injectors, wide band and intake are set up. Sent from my SAMSUNG-SGH-I317 using Tapatalk www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
