SpecBamf41 Posted November 3, 2014 Author Share Posted November 3, 2014 well my turbo is shot, weather its because the banjo filter was bad, or because i removed it, or because i went stage 2....we'll never know the answer. got alot of axial shaft play, no radial play. going bnr 18g with the ip&t oil line and filter kit. so, replace the filters, and replace your ocv. BNR18g on 93oct Link to comment Share on other sites More sharing options...
Max Capacity Posted November 3, 2014 Share Posted November 3, 2014 So, did you catch the turbo before it put metal into the oil pan ? Here's mine. http://legacygt.com/forums/showthread.php/142-000-miles-oem-turbo-168561.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
