Jack2052 Posted June 5, 2014 Share Posted June 5, 2014 I have a 2007 Tribeca engine and 5seat transmission in a mid engine track day car. I want to Flash the factory computer to run this engine and transmission in this, stand alone, configuration. Any advise on how to achieve this goal? Thanks, Jack Link to comment Share on other sites More sharing options...
Th3Franz Posted June 6, 2014 Share Posted June 6, 2014 You can tune it with open source - it supports the factory 07 Tribeca ECU and automatic transmission. http://www.romraider.com/Documentation/SupportedECUs -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
JermTheElf Posted June 6, 2014 Share Posted June 6, 2014 pics? Link to comment Share on other sites More sharing options...
Jack2052 Posted June 7, 2014 Author Share Posted June 7, 2014 Go to the Title location on YouTube for videos. Link to comment Share on other sites More sharing options...
Jack2052 Posted June 7, 2014 Author Share Posted June 7, 2014 Does anybody know of a Stand Alone computer that will run a 2007 3.0 engine? Link to comment Share on other sites More sharing options...
Th3Franz Posted June 7, 2014 Share Posted June 7, 2014 Why do you need to go standalone? The factory 32 bit ECU is very capable.. That said you could look at AEM or Vipec but you will probably need to do some wiring. Edit: just found your video. Wow two 6-cyls in tandem. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Dujo Posted June 7, 2014 Share Posted June 7, 2014 Link for awesomeness. Welcome to LGT.com! Link to comment Share on other sites More sharing options...
Jack2052 Posted June 8, 2014 Author Share Posted June 8, 2014 You can also see more on Porsche 917/10 Replica 2, 3 and 4, "and Formula One car". Link to comment Share on other sites More sharing options...
Jack2052 Posted June 8, 2014 Author Share Posted June 8, 2014 TH3Franz, I have an OEM engine and transmission computers but I need a harness from it to the engine as the one I have is damaged. I am not a mechanic let alone an electrician so talking about wiring and computers is like Greek to me. I can't speak the language! I would like to reprogram the OEM computers to allow them to work without security and emissions or any other system I don't need. Can wires be removed from the connectors and new wires installed? They were cut of too close to the connector for slicing. I live in East Hartford, CT., if anybody wants to come see what I have and can offer some advise. Thanks, Jack Link to comment Share on other sites More sharing options...
Dujo Posted June 8, 2014 Share Posted June 8, 2014 Sounds like you may actually need a tuner who knows what he's doing. User Max Capacity lives in Tolland, I believe and he recommends Tuning Alliance in CT. Shoot them an email and ask. I also use and recommend Bren of BrenTuning in Charlton, MA. Obviously, this is not a standard, common thing to do, but either one of them might be able to help you having significant experience with Subaru ECUs. Can't hurt to ask. Link to comment Share on other sites More sharing options...
Th3Franz Posted June 9, 2014 Share Posted June 9, 2014 You will probably need to have an immobilizer paired with the ECU and just leave it installed near the computer. Disabling the emissions codes is easy. You can un-pin the connectors by flipping up the the locking clip and using a pick to slide the pin out. They make special tools for doing this. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
RallyMachine Posted June 10, 2014 Share Posted June 10, 2014 Very cool build, but if I were a potential buyer using this for a track day I would have concerns about the driveline configuration. Since you are using a subaru transmission and it looks like you will have the rear wheels accepting axles from the transmissions front axle position. I'm almost positive that that is an open differential. Any hard cornering would lead to spinning the inside tire and would lead to reduced grip. I'm not sure if the transmission ecu could be tuned to have a simulated LSD in the front but something to look in to/think about. I'm not positive with how the auto transmissions work but you might have some difficult with the VDC (traction control) as well... If there's no rear axle connect it might think that the "rear wheels" are loosing traction all the time. It might be a little late/not in the budget, but an STI 6 speed has a helical front diff that would give the rear wheels (front diff) some limited slip capabilities. But that's a manual transmission and pretty expensive too. Link to comment Share on other sites More sharing options...
Jack2052 Posted June 11, 2014 Author Share Posted June 11, 2014 I was told that a fuse could be installed or removed to allow the transmission to run in a front drive configuration. Are there any other opinions on the 2007 5eat front transmission being used in a rear wheel drive position? I was planning on using the factory trans computer with only the inputs it needs to run the transmission at a basic level. I can't upload photos for some reason. Something about a security code. Link to comment Share on other sites More sharing options...
Jack2052 Posted June 11, 2014 Author Share Posted June 11, 2014 If you had the following items bolted into a tube chassis and wanted to get things working as cheap as possible, how would you make them run? 1. A 2007 Subaru 3.0R engine with an engine harness. 2. The engine has a mechanical throttle body but I do have the OEM one. 2. The ECU with connectors but no harness. 3. A 5eat transmission with the TCM and harness connecting them. Jack Link to comment Share on other sites More sharing options...
Th3Franz Posted June 11, 2014 Share Posted June 11, 2014 Try to find wiring harnesses from a wrecked car with a 3.0R engine. You may be best off selling the 5EAT and getting a standard transmission due to the fact that you will not need a TCM and it won't be affected by VDC. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
RallyMachine Posted June 12, 2014 Share Posted June 12, 2014 Plus who knows if the transmission can handle 500bhp... To me the sti trans would be the best option if it bolts up. Link to comment Share on other sites More sharing options...
Jack2052 Posted June 12, 2014 Author Share Posted June 12, 2014 I'm looking for a harness now. I have custom made $$$ half shafts. I don't know if the CV joints or if the width of the diffs are the same. In the beginning I felt mid-engine shifting, with the driver and the shifter on the right side and the shift linkage on the left side, would be too big a problem. Considering what I was doing, I wanted to eliminate as many problems as possible. I never imagined how big a problem the electronics would be. Link to comment Share on other sites More sharing options...
Jack2052 Posted June 12, 2014 Author Share Posted June 12, 2014 Rally Machine, Someone told me the horsepower might go to 400 but the torque might double. Who knows? This car won't be for full blown, 9/10s track day driving. More of a high speed exhibition car and hillclimbs. Maybe at vintage events also. Link to comment Share on other sites More sharing options...
RallyMachine Posted June 12, 2014 Share Posted June 12, 2014 Yeah I would much rather deal with mechanical setup issues than electronic ones. It's hard to tell how much power it will make since it's an experimental engine but I just know that some of the legacy gt 5eat transmissions can have difficulties at increased power levels. Needless to say there will be a lot of wiring to be done. Link to comment Share on other sites More sharing options...
Th3Franz Posted June 12, 2014 Share Posted June 12, 2014 You may want to look into how Factory Five has their 818 shifting arrangement. They are set up to use a manual 5 speed Subaru transmission and 4 cylinder engine. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Jack2052 Posted June 13, 2014 Author Share Posted June 13, 2014 The Factory Five shifter is in the center so the rods or cables run straight back. My shifter is on the right side of the tub so, the cables would have to go around the right side of the driver, who sits on the right, then get around the mid engine and then to the left rear of the transmission. On the 5eat, the shift control is in the right so I have a tube that runs down the right side and connects to the OEM cable. This car was not designed for 9/10 driving. It's for an older guy like me to take to track days, Porsche club meets, vintage race car events, hillclimbs and just to be the coolest guy around with a Porsche 917/10 Can Am Car!!!!!!!!!! It can be driven fast on the straight and brake deep into the corners but then you'd have to ease it out of the corners or from a dead start. Link to comment Share on other sites More sharing options...
Jack2052 Posted July 8, 2014 Author Share Posted July 8, 2014 I have acquired a dashboard wiring harness from a 2007 Tribeca and have identified the connectors necessary to plug into the ECU and TCU. I have the fuse boxes and the relays. Does anybody know where I can send the computers to have them reprogrammed to run the engine and transmission OUTSIDE the vehicle? No security system, no resister key, no VVT, No emissions, etc. ? Thanks, Jack Link to comment Share on other sites More sharing options...
whitetiger Posted July 8, 2014 Share Posted July 8, 2014 ^what you are asking about has never been done as far as i know especially with the auto trans. 07+ ECU's are canbus IIRC. They need a full on reflash beyond opensource to do what you are asking about. You may be better off with a standalone aftermarket unit and having a qualified tuner build the tune from the ground up. AEM has some nice options. start there. Link to comment Share on other sites More sharing options...
Jack2052 Posted November 26, 2014 Author Share Posted November 26, 2014 Does anybody know which manual box will bolt up to an SVX 3,3L engine? Link to comment Share on other sites More sharing options...
Sgt.Gator Posted December 12, 2014 Share Posted December 12, 2014 Jack did you figure out your engine management? I was going to suggest HalTech, but you already tried that in one of your earlier videos. Ad=nd why are you asking about the SVX engine, are you tossing your 2 x EZ30Rs? Nothing like a race track to find the weak points in man and machine. "Good Judgement comes from Experience. Experience comes from Bad Judgement" Link to comment Share on other sites More sharing options...
