jduani Posted June 2, 2014 Share Posted June 2, 2014 Hey Everyone, I am not sure this is the right section so mods please move this if I am wrong. (Sorry) I have a built motor, Rotated turbo Spec.B with a rotated IM. and the problem I am having is that the couple that connects the throttle body to the intercooler piping rub just a little bit. I was talking to the guy that built my motor and he said there was a company called TigWerks that used to make a lower motor that made the motor sit a 1/4" lower in the car. However I cant seem to track them down at all. Does anybody know where I can get my hands on a set of these motor mounts or what else I can do to lower my motor haha. Thanks For the Help Link to comment Share on other sites More sharing options...
thisisthenewsic Posted June 2, 2014 Share Posted June 2, 2014 i know he stopped making alot of stuff. i think he really only builds rotated pipings kits now...... consider notching the hood a little bit if possible? Link to comment Share on other sites More sharing options...
jduani Posted June 2, 2014 Author Share Posted June 2, 2014 The hood is notched as much as i could. I am going to see if i could notch it some more. The rubbing is just slight enough to be an issue as time goes on. I messaged him on facebook. Im curious to see him he will answer, if its the same guy. Link to comment Share on other sites More sharing options...
thisisthenewsic Posted June 2, 2014 Share Posted June 2, 2014 i just read one of his posts, hes not even making the turbo manifold kits anymore. he did his last batch n thats it. but yeah worth a shot to try n message him. do you have phenolic spacers between head and intake manifold? what width? Link to comment Share on other sites More sharing options...
jduani Posted June 9, 2014 Author Share Posted June 9, 2014 i just read one of his posts, hes not even making the turbo manifold kits anymore. he did his last batch n thats it. but yeah worth a shot to try n message him. do you have phenolic spacers between head and intake manifold? what width? Yea I do have spacers, it was the only way to get everything to fit. They are the grimspeed ones i think they are the smaller ones if i remember correctly i think 3mm but i could be mistaken. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 9, 2014 Share Posted June 9, 2014 Can you have a machine shop modify a set of OEM mounts ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
thisisthenewsic Posted June 9, 2014 Share Posted June 9, 2014 hm. im running a rotated sti manifold with 9.5mm kstech spacers and mine clears. Link to comment Share on other sites More sharing options...
