DONDOLO Posted June 1, 2014 Share Posted June 1, 2014 So I was just driving and my nav and my deck went out in my 2006 spec B. The red back lighting still works and I can eject and load the discs but no music. My climate controls also aren't working.. No display on the climate controls or cd display, except when I remove a disc I can see the words (load disc etc) I'm not sure what it can be I'm going to check all the wiring for lose plugs in the morning. Anything else I can check? Link to comment Share on other sites More sharing options...
firehawk618 Posted June 1, 2014 Share Posted June 1, 2014 I've personally never had this problem but I have read other threads on here with people describing the exact same problem. 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 1, 2014 Share Posted June 1, 2014 How old is the battery, these cars act funny when the battery terminals are dirty giving out a weak signal. Seems the HVAC and Radio start to do funny things. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DONDOLO Posted June 1, 2014 Author Share Posted June 1, 2014 How old is the battery, these cars act funny when the battery terminals are dirty giving out a weak signal. Seems the HVAC and Radio start to do funny things. I'm not sure I need to check it because messing with the wires today didn't work at all. Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted June 1, 2014 Share Posted June 1, 2014 As mention by max. & some other things to check; -Battery strength & terminals -Ground cable (1 on coming from ea, head to frame rail & 1 more from tranny to pitch mount on fire wall. -fuses -wire harnesses Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
firehawk618 Posted June 2, 2014 Share Posted June 2, 2014 If grounding is suspect a fairly easy test is just run a small jumper wire from the - term on the battery directly to the radio chassis and hold it on there. If all works properly when the radio is manually grounded then I'd say save your effort and look elsewhere for the issue. 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
DONDOLO Posted June 3, 2014 Author Share Posted June 3, 2014 ok thank you the help is appreciated ill be working on this over my 5 day weekend this weekend along with a few other things. ill keep you all posted Link to comment Share on other sites More sharing options...
DONDOLO Posted June 7, 2014 Author Share Posted June 7, 2014 Hey I want to say thanks for all the help. It was such a simple fix idk why I panicked. I just checked all the fuses and found my problem. I appreciate all the advice though Link to comment Share on other sites More sharing options...
Max Capacity Posted June 7, 2014 Share Posted June 7, 2014 Good, but why did the fuse blow ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DONDOLO Posted June 7, 2014 Author Share Posted June 7, 2014 Good, but why did the fuse blow ? I honestly have no idea. I was just driving and it happened. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 7, 2014 Share Posted June 7, 2014 Which fuse ? May be one of can help figure out why ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DONDOLO Posted June 8, 2014 Author Share Posted June 8, 2014 Which fuse ? May be one of can help figure out why ? It was 15A Under the steering wheel. Link to comment Share on other sites More sharing options...
firehawk618 Posted June 9, 2014 Share Posted June 9, 2014 Good, but why did the fuse blow ? Yeah, they don't just blow at random. 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
DONDOLO Posted June 9, 2014 Author Share Posted June 9, 2014 Yeah, they don't just blow at random. Well dang idk what could have caused it. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 9, 2014 Share Posted June 9, 2014 Something is wrong in the circuit, chaffed wire ? Ok, which 15amp fuse was it ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DONDOLO Posted June 9, 2014 Author Share Posted June 9, 2014 Something is wrong in the circuit, chaffed wire ? Ok, which 15amp fuse was it ? The one that I'm pointing at us the one that blue. (the lighter blue 15) Link to comment Share on other sites More sharing options...
Max Capacity Posted June 9, 2014 Share Posted June 9, 2014 If you notice on the door there is a map of what each fuse does. Can you read the map ? http://people.csail.mit.edu/ilh/vacation/ thats the service manual. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DONDOLO Posted June 9, 2014 Author Share Posted June 9, 2014 If you notice on the door there is a map of what each fuse does. Can you read the map ? http://people.csail.mit.edu/ilh/vacation/ thats the service manual. Yes it was the audio/NAV fuse Link to comment Share on other sites More sharing options...
Max Capacity Posted June 9, 2014 Share Posted June 9, 2014 I guess you need to post a thread in that forum next ? Good Luck, I hate electrical issues. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DONDOLO Posted June 9, 2014 Author Share Posted June 9, 2014 I guess you need to post a thread in that forum next ? Good Luck, I hate electrical issues. Yeh me too. But I appreciate the help Link to comment Share on other sites More sharing options...
Max Capacity Posted June 9, 2014 Share Posted June 9, 2014 I would think you need to have the wireing checked to make sure its in good shape. Something caused the fuse to blow. May be a radio install shop can test the system for you. We have Long Radio, Jo Dee's, etc, there are lots of places. Or you could of just had a weak fuse....better to make sure and not have a bad wire cause more damage...have you ever seen a car catch on fire... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DONDOLO Posted June 10, 2014 Author Share Posted June 10, 2014 I would think you need to have the wireing checked to make sure its in good shape. Something caused the fuse to blow. May be a radio install shop can test the system for you. We have Long Radio, Jo Dee's, etc, there are lots of places. Or you could of just had a weak fuse....better to make sure and not have a bad wire cause more damage...have you ever seen a car catch on fire... Yeh for sure. Will do Link to comment Share on other sites More sharing options...
DONDOLO Posted June 10, 2014 Author Share Posted June 10, 2014 I appreciate the help Max capacity Link to comment Share on other sites More sharing options...
DONDOLO Posted June 11, 2014 Author Share Posted June 11, 2014 Well the fuse blew again..... ****!!!!! Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted June 11, 2014 Share Posted June 11, 2014 Is it the same fuse, that powers your cig. lighter. My ex-girlfriends 05 WRX cig. lighter locking nut came loose. Every time she pushed or pulled the cell charger out. She would pop a fuse. Other then that, need to dive in to the wire harness & look for shorts. Best of luck, getting it all straighten out. Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
