MasAyinde Posted May 30, 2014 Share Posted May 30, 2014 I just installed the Fumoto valve (with no nipple, unfortunately) and when tightened down, the opening is kind of facing up. I can run a tube through the undercarriage easily enough to change the oil, but I'm not sure what dimension tube I need. Does anyone know the outside diameter of the chode at the end of the valve or can someone measure it for me? Link to comment Share on other sites More sharing options...
Max Capacity Posted May 30, 2014 Share Posted May 30, 2014 I seem to think it's 1/2" I also think you can unthread that end and take it with you to the store. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
