08 LGT Posted May 24, 2014 Share Posted May 24, 2014 At 99,600 miles, it seems the rear left wheel bearing is now on the way out. There's a loud humming that gets worse with increasing speed from that wheel, and I'm guessing the bearing must be the culprit. Can anyone confirm that this is the correct part assembly I need to replace it? Thanks! http://subaruparts.com/parts/2008/SUBARU/Legacy/GT%20Limited?siteid=218240&vehicleid=201803§ion=REAR%20SUSPENSION&group=REAR%20SUSPENSION&subgroup=BRAKE%20COMPONENTS&component=Hub%20assy Link to comment Share on other sites More sharing options...
12sechatch Posted May 24, 2014 Share Posted May 24, 2014 Yes, that is correct Check the "oem catalog" at subarugenuineparts.com, last time I checked they were cheaper than that. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 24, 2014 Share Posted May 24, 2014 That's for a 2008. the rears are the same, doesn't matter which side. Same with the fronts there is no left or right. http://legacygt.com/forums/showthread.php/idea-web-links-saved-various-parts-219238.html You can find in there too 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
PearlBlueGT Posted May 25, 2014 Share Posted May 25, 2014 Check out ebay, you can buy Timken wheel bearing for under $100 shipped. Link to comment Share on other sites More sharing options...
