TLL24 Posted May 9, 2014 Share Posted May 9, 2014 Hey anyone know where I could order the plastic screws/bolts that lock the engine oil filter plastic cover on under the front of my legacy? It's the little like 10 inch by 10 inch square-ish plastic cover that I'm talking about. 3 out of 4 of the plastic screws/bolts (whatever they are) that lock it into place fell out and now the cover is hanging by just the one. I suppose I could just take the cover off, but I'd like to be able to lock it into place again if I can order those pieces. Thanks! Link to comment Share on other sites More sharing options...
apexi Posted May 10, 2014 Share Posted May 10, 2014 It looks like the dealer might not have a bad price on the clips if you want to try them. The problem is, there are 3-4 different part numbers for the clips, and I'm not sure what the difference between the part numbers is. You can get clips from the link below too, and I'm sure there are other places that sell them online as well. http://www.clipsandfasteners.com/Subaru_Grill_Bumper_Clips_s/304.htm I would also consider napa auto parts if you have one near you. A napa near me has a binder with a ton of physical clips laminated in it so you can bring in a clip, compare the size of the clips, and then pick out a bag of the clips from the display. That's what I did when I bought replacement clips that hold the air flap in the wheel well area http://legacygt.com/forums/showpost.php?p=3874805&postcount=21 Link to comment Share on other sites More sharing options...
BigBad Posted May 10, 2014 Share Posted May 10, 2014 Clipsandfasteners.com is the best place to get any of the Subaru clips in bulk cheap. They sell them in bags of 15 clips. For the oil filter cover use 21530 (oem 909130067) For engine cover use 21594 (oem 909130051) I also got bumper/fender clips 21420 Link to comment Share on other sites More sharing options...
Max Capacity Posted May 10, 2014 Share Posted May 10, 2014 http://legacygt.com/forums/showthread.php/idea-web-links-saved-various-parts-219238.html Also NAPA or most auto parts stores have them too. I should replace the cover on my wagon, its been like half there for years. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
TLL24 Posted May 10, 2014 Author Share Posted May 10, 2014 Clipsandfasteners.com is exactly what I was looking for, thanks for the help! Link to comment Share on other sites More sharing options...
iNVAR Posted May 11, 2014 Share Posted May 11, 2014 Ebay also works. Just search for the part number. Super cheap when shipped from HK/China, but takes a while to reach you, lol. Link to comment Share on other sites More sharing options...
