Max Q Posted May 1, 2014 Share Posted May 1, 2014 Is everyone generally happy with the taller rear wagon springs on the sedan or are we using saggy butt spacers with those too? If so, which size? Also to clarify, swifts front sedan and wagon springs are the same part and it's just the rears that are different? Link to comment Share on other sites More sharing options...
PtPixel Posted May 1, 2014 Share Posted May 1, 2014 I've got sedan swifts on my 08 specB sedan. The back does sag a little but I don't mind it that much. You shouldn't need spacers if you're using the wagon springs on the sedan. The saggy butt spacers are usually 3/4" -1" thickness I think. 3/4" are used more often from what I've seen. Yes swift fronts are identical, wagon and sedan rears are different. Link to comment Share on other sites More sharing options...
Max Q Posted May 2, 2014 Author Share Posted May 2, 2014 Perfect. Then wagon springs it is. Thanks! Link to comment Share on other sites More sharing options...
SleeperLGT Posted May 2, 2014 Share Posted May 2, 2014 Spec b bilsteins and swift wagon specific springs. Evens it out pretty nice with the taller rear springs. http://i24.photobucket.com/albums/c8/jaycashmoney10/Mobile%20Uploads/20140426_124833_RichtoneHDR_zps0naqfz5b.jpg Link to comment Share on other sites More sharing options...
Connor Posted May 3, 2014 Share Posted May 3, 2014 Stock spec.B Bilsteins w/ Swift Wagon springs, no spacers. Link to comment Share on other sites More sharing options...
Max Q Posted May 3, 2014 Author Share Posted May 3, 2014 Exactly what I needed guys. Thanks. Link to comment Share on other sites More sharing options...
Charlie Tango Posted June 7, 2014 Share Posted June 7, 2014 Yes! Mee too! Thanks. Link to comment Share on other sites More sharing options...
