petethapitbull Posted April 23, 2014 Share Posted April 23, 2014 I'm coming up on 88k miles on my 06 legacy. I'm the second owner - bought the car around 75k, but i'm not sure if the first owner ever changed the differential fluid. Should I change it anyway? if so, which is the recommended fluid for it? What is the milage interval it should be changed at? Thanks in advance. Link to comment Share on other sites More sharing options...
mr.hicksta Posted April 23, 2014 Share Posted April 23, 2014 Yes, you should definitely change them. I would recommend using Subaru Extra-S for the trans and diff. Your local dealership may carry it and if they don't many of the vendors here can get it for you. As for the interval, I like to change mine every 30K or so. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 23, 2014 Share Posted April 23, 2014 What tranny 5mt or 5eat ? 5eat takes different fluid. Exrta-S is the best stuff for the front diff and rear diff or all diffs on mt cars. (mt=manual transmission) change is every 30,000 miles. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
CrowNaza86 Posted April 24, 2014 Share Posted April 24, 2014 For a 5EAT, F&R diff take extra-s or any 75W-90 fluid. Get 3qts worth. Center just shares the trans fluid. Agree 100% on the interval, every 30k is a cheap insurance to ensure it's running properly. Link to comment Share on other sites More sharing options...
petethapitbull Posted April 25, 2014 Author Share Posted April 25, 2014 It's an automatic (Non-turbo). 3qts would be enough for both F&R or 3qts for each? What website should I order it from? Thanks! Link to comment Share on other sites More sharing options...
CrowNaza86 Posted April 25, 2014 Share Posted April 25, 2014 3qts is enough for both F&R. Read the manual or service guide for how much each takes. Link to comment Share on other sites More sharing options...
