Brad_J Posted August 29, 2005 Share Posted August 29, 2005 First off, I'm new to this forum. So I apologize if this isn't the right forum to post this. 97 LGT sedan w/auto (4.444:1 differentials ?) My rear differential is toast (I think). The inner CV joint has over 1/8" of radial play in the diff, so I might as well upgrade while I'm at it. Will a LSD differential and CV axles from a 2001 or newer 2.5RS Impreza (auto) bolt in? I've searched and seen swaps like this, but no mention of modifications required. Will the housing bolt in, are the outer CV's the same? I know the axle shafts aren't the same length with the LSD's, but I'll get those with the diff anyhoo. Low mileage salvage parts are hard to find for these older years, so I'm hoping the newer parts are an option... Brad Link to comment Share on other sites More sharing options...
rao Posted August 29, 2005 Share Posted August 29, 2005 IIRC, the rears are identical. I believe the axles on the leagacy are longer so y ou would want to reuse yours. I've done the swap on an older legacy turbo and it was a breeze, so long as you have the right gear ratio. The bast place to ask the queston and find our for sure is the nasioc "subaru conversions" forum. It might be answered for you in one of the stickys. Here is a good start: http://forums.nasioc.com/forums/showthread.php?s=&threadid=401263 Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Brad_J Posted August 29, 2005 Author Share Posted August 29, 2005 Thanks Rob. I still haven't gotten my e-mail for activating my NASIOC membership, so I can't post or search there (and I can't find a link to get ahold of anyone there to resolve it). I'll see if I can sweet talk the 'yards here to let me walk around and measure. Thanks for the quick reply. Brad Link to comment Share on other sites More sharing options...
Brady Posted September 1, 2005 Share Posted September 1, 2005 LSD was not in the 2.5 rs in 2002 or 2003. Don't know about 2004 onward. Link to comment Share on other sites More sharing options...
Brad_J Posted September 2, 2005 Author Share Posted September 2, 2005 You're right Brady. There isn't much for 2000-2001 RS's around here, so I'm hoping I can get one out of a newer Legacy or Forester (there's a ton of those around). I found more info on NASIOC about inner/outer CV axle splines for different years, so I'm a little more confident now. Thanks for the reply. Brad Link to comment Share on other sites More sharing options...
