05legGT Posted April 2, 2014 Share Posted April 2, 2014 I recently noticed my turbo has become extremely loud. I used to have an SPT intake and it sounds similar to how it sounded when I had the intake on it. basically just the whooshing sound of the turbo spooling. I have an sti up pipe with an autospeed cat back. I have an infamous stage 2 tune and a K&N panel filter and a turbo xs hybrid 50/50 blow off valve. my boost should be peaking at 17.5 psi and its cutting off at 13.5ish. Im also noticing a lot of lag and the blow off valve is much more quiet. I have tried reflashing. Has anyone had anything like this happen? Could it be a boost leak? I have searched and cant seem to diagnose anything so thanks for any input and advice Link to comment Share on other sites More sharing options...
lingling1337 Posted April 2, 2014 Share Posted April 2, 2014 It could be a boost leak yes. But if it sounds like your turbo wheel is scraping against something then you may have a turbo problem. Link to comment Share on other sites More sharing options...
chato Posted April 2, 2014 Share Posted April 2, 2014 loud whooshing is usually the turbo inlet slipping off or sometimes TMIC/TB connection. Link to comment Share on other sites More sharing options...
05legGT Posted April 2, 2014 Author Share Posted April 2, 2014 Im not hearing any screeching noises just a loud whooshing and a serious lack of power. Could it be the blue tee? I havent checked anything underneath the TMIC yet. Link to comment Share on other sites More sharing options...
discojon Posted April 2, 2014 Share Posted April 2, 2014 Bov leaking Sent from my SGH-I747 using Tapatalk Link to comment Share on other sites More sharing options...
05legGT Posted April 2, 2014 Author Share Posted April 2, 2014 I thought maybe it could be the bov. How would I know if that is the problem? Link to comment Share on other sites More sharing options...
05legGT Posted April 2, 2014 Author Share Posted April 2, 2014 I haven't taken the bov off but I did inspect it and everything looks ok Link to comment Share on other sites More sharing options...
Mike07LGT Posted April 2, 2014 Share Posted April 2, 2014 Put the factory bov back on and see if it fixes the problem then you will know if its that or not... 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
05legGT Posted April 2, 2014 Author Share Posted April 2, 2014 I will try that tonight. Is it possible that the BOV could be stuck open? Link to comment Share on other sites More sharing options...
Nightmaresmk Posted April 2, 2014 Share Posted April 2, 2014 mine whistles when it's spooling. no boost leak since i hit PSI i'm set for. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 2, 2014 Share Posted April 2, 2014 The loud turbo noise isn't being emitted by the BOV. The BOV is well downstream, a small orifice and wouldnt sound like massive spoolage The turbo inlet slipping off or having a crack or the connector btwn the turbo and the TMIC is more likely the culprit. A more simple fix, if you have the block off plate, is to set the BOV to full recirc. Link to comment Share on other sites More sharing options...
chato Posted April 2, 2014 Share Posted April 2, 2014 you can just visually inspect the inlet to turbo connection and tmic/tb connection. you'll generally be able to see if it is slipping off, hose clamps will be askew, maybe some slight oily residue at the tb/tmic connection. if you have access to a compressor, try putting a paint can where your air intake goes and pressurizing the whole intake up to about 12psi through the small line off the bpv. if you're still on stock inlet and stock tb/tmic I'd inspect closely, my inlet had a tear and tb/tmic had blown out on the tb side at 110k. Link to comment Share on other sites More sharing options...
05legGT Posted April 2, 2014 Author Share Posted April 2, 2014 Ok the turbo inlet hose was the culprit. It was completely disconnected from the inlet. The car runs great now but now I'm hearing a loud screeching sound at wot. The sound changes tones sometimes it's a low pitch whistle. Could this be signs of a future turbo failure? Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 2, 2014 Share Posted April 2, 2014 Ok the turbo inlet hose was the culprit. It was completely disconnected from the inlet. The car runs great now but now I'm hearing a loud screeching sound at wot. The sound changes tones sometimes it's a low pitch whistle. Could this be signs of a future turbo failure? That is your turbo failing. It's contacting the housing due to excessive shaft play Now you get to look for a new turbo BEFORE it craps and takes your engine with it. Link to comment Share on other sites More sharing options...
Gex Posted April 2, 2014 Share Posted April 2, 2014 Yeah probably should stop driving it till you pull the downpipe and check the turbo. Turbo goes and you keep driving it, bad things happen mmmkay. Link to comment Share on other sites More sharing options...
05legGT Posted April 3, 2014 Author Share Posted April 3, 2014 Is there easy access to the inside of the turbo to check for shaft play? I want to do this tonight if possible. If I unbolt my down pipe from the turbo will it allow me to reach my finger in there? Also if It is my turbo, what does everyone recommend as far as what turbo to get and where to buy it? I would probably get a rebuilt one to save some money. I'm not opposed to the idea of getting a bigger turbo and aftermarket intercooler but I want to keep my car reliable. What would be the next step up from the vf40? Would anything bolt right up? Link to comment Share on other sites More sharing options...
khurlburt Posted April 3, 2014 Share Posted April 3, 2014 A bnr 16g or a vf-52 are both good upgrades for the stock vf-40. You're correct about pulling the downpipe. Check the shaft for play while the downpipe is off, then go from there. Also remember, if you get an upgraded turbo you'll need a tune to go along with it to optimize it. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Gex Posted April 3, 2014 Share Posted April 3, 2014 To check the turbo. 3 bolts intercooler,2 hoses throttle and bpv,5? Bolts turbo heat shield,2 bolts down pipe to mid pipe. One bolt transmission mount on down pipe, and 5 nuts on the down pipe holding on the turbo. Think you need a 10,12, and 14mm sockets and box wrenches. Pretty easy! Link to comment Share on other sites More sharing options...
