SATSFYD Posted March 11, 2014 Share Posted March 11, 2014 Has anyone had a surge coming from the engine when driving a constant speed or under lite acceleration? <- ---- May cars information. I don’t have any engine codes coming from the engine (Read the ECU with my accessport.) I put in some "SEAFOAM" thinking their was/is a fuel delivery problem... didn't make the surge go away. Thoughts? **There are two types of people in the world, those who build horsepower and those who buy it. Which one are you? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 11, 2014 Share Posted March 11, 2014 Yes, its a common issue with these cars. When I had my first test drive in june 04 I told the salesman the car had a surging problem. The car had just been unloaded and they had to pull the plastic off the seats so I could drive it. I didn't buy that car. My wagon had the issue too but not a noticeable as that first car. My Tuner has been able to fix the issue. http://www.tuningalliance.com 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
SATSFYD Posted March 11, 2014 Author Share Posted March 11, 2014 Did he say what it was? ...I didn't notice it until I put the stage 1 program in. **There are two types of people in the world, those who build horsepower and those who buy it. Which one are you? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 11, 2014 Share Posted March 11, 2014 I'm sure he may have said at one time, but he has a thread in the Vendor Forum. Or email him from his site. He's good with things like that. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
SATSFYD Posted March 11, 2014 Author Share Posted March 11, 2014 ^Sweet thanks. I emailed him. **There are two types of people in the world, those who build horsepower and those who buy it. Which one are you? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 11, 2014 Share Posted March 11, 2014 Your welcome...he really is that good. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Nubie Posted March 11, 2014 Share Posted March 11, 2014 I have the same thing, I only notice it at about 60-70mph holding constant throttle. Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 12, 2014 Share Posted March 12, 2014 Front O2 sensor can cause that kind of surging too and it won't necessarily set a CEL. Find a known good one and replace it and try it again and see if it takes the surging away. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 12, 2014 Share Posted March 12, 2014 Good point ^, at the age of a 05-06, it may be a good idea just to replace the front O2 any way. I use a OEM sensor. I think JmP has some info in his sticky up top. It may be good to clean the MAF sensor too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
SATSFYD Posted March 12, 2014 Author Share Posted March 12, 2014 ^Would you clean the MAF with brake cleaner? **There are two types of people in the world, those who build horsepower and those who buy it. Which one are you? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 12, 2014 Share Posted March 12, 2014 No. Auto parts stores will have a can of MAF cleaner use that. Spray it well, let the crap fall off it, let it dry. put it back in. You can even leave the plug on it. I got a CEL one time after cleaning, I reset the ECU, it never came back. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FJuan Posted March 12, 2014 Share Posted March 12, 2014 You can use brake cleaner, I've been doing it for years before they even came out with MAF cleaner. It's basically the same thing, it's just another way for them to charge you $4 more over brake cleaner. I do not recommend using Carb cleaner, since it leaves a mild residue. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 12, 2014 Share Posted March 12, 2014 CRC MAF cleaner is primarily Hexane (80-90%) and if you find any other cleaner (brake parts cleaner, electrical contact cleaner, spray degreaser) that contains between 80-90% Hexane, you'll be fine. Link to comment Share on other sites More sharing options...
SATSFYD Posted March 14, 2014 Author Share Posted March 14, 2014 So I cleaned the MAF last night and it was dirty enough not to be able to see the element inside the amber glaze... drove to work this morning with NO surge. **There are two types of people in the world, those who build horsepower and those who buy it. Which one are you? Link to comment Share on other sites More sharing options...
firehawk618 Posted March 14, 2014 Share Posted March 14, 2014 I'll save you some time. There's a thread with over 150 posts regarding this very issue: http://legacygt.com/forums/showthread.php/stumble-cruise-only-218669.html 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
firehawk618 Posted March 14, 2014 Share Posted March 14, 2014 So I cleaned the MAF last night and it was dirty enough not to be able to see the element inside the amber glaze... drove to work this morning with NO surge. Give it a few days to come back. 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
