beanmachine Posted March 11, 2014 Share Posted March 11, 2014 So I just bought an accessport off of another member here and have not used one on a Subaru before. With my old ms3 I had to flash a map to it the. Drive calmly for 100~ miles while the car adjusted and then could have fun with it. Do I have to do that with my 2007 LGT wagon? And second are there different maps for manual and auto trans? I realize 2007 only came in auto but figured I'd ask anyway but I'm anxious to see how I like the stage 1 map feels compared to stock. Thanks. Sent from my HTC6435LVW using Tapatalk Link to comment Share on other sites More sharing options...
rob-2 Posted March 11, 2014 Share Posted March 11, 2014 Same process. it will be clear when you connect to the car. Link to comment Share on other sites More sharing options...
beanmachine Posted March 11, 2014 Author Share Posted March 11, 2014 Thanks. I guess it's the same way with most boosted cars then. With my 03 mach 1 all I needed to do was load a map and let it rip no waiting necessary. Guess it'll be a day or two till I can really have fun with it then. Sent from my HTC6435LVW using Tapatalk Link to comment Share on other sites More sharing options...
GTEASER Posted March 11, 2014 Share Posted March 11, 2014 I don't think that you have to wait, just drive it for a few miles to make sure the car isn't acting strange, then enjoy. The ECU will continue fine learning for a few weeks but nothing that would limit your hooning. My tuner flashed mine to Cobb OTS Stage1 while the car was on the dyno after OEM map baseline pulls. He let it run for a few minutes, blipped the throttle a couple times, and did 3 Stage1 dyno pulls. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Max Capacity Posted March 11, 2014 Share Posted March 11, 2014 When I first loaded AP into the wagon back in Dec 04 I drove the car to VT after loading it. The car ran great, just drive it like you normally do. Yes I believe there are different for a 5mt and a 5eat. God to Cobb's site and download the manual for the AP you'll find lots of info there. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
beanmachine Posted March 11, 2014 Author Share Posted March 11, 2014 Cool thanks for the info guys. I'll probably drive normal to and from work tomorrow then get into it to see how different it feels Sent from my HTC6435LVW using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted March 11, 2014 Share Posted March 11, 2014 Oh, your going to like it, I remember saying to my son, "this is how the car should have come from the factory" that was at stage 1 93 octane. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
beanmachine Posted March 15, 2014 Author Share Posted March 15, 2014 So it says the maps on my ap are for a 2008 and I have a 2007. Is that fine considering theyre the same? Sent from my GT-N8013 using Tapatalk Link to comment Share on other sites More sharing options...
kzr750r1 Posted March 15, 2014 Share Posted March 15, 2014 Cobb has base maps for all years on their site. You'll need AP manager loaded on your PC to import and export to the AP. Also while your at it get a copy of accessTuner Race so if you go with custom tunes they can be available for use after saving them in AT Race then moving othem over to the AP with AP manager. Link to comment Share on other sites More sharing options...
John J Posted March 15, 2014 Share Posted March 15, 2014 Download the latest AP manager from Cobb: http://www.cobbtuning.com/Accessport-Off-The-Shelf-Maps-s/40100.htm#/v/accessport/ap-manager Find the map you want: http://www.cobbtuning.com/Accessport-Off-The-Shelf-Maps-s/40100.htm#/v/accessport/maps/subaru/lgt/LGT-Map-Grid Download map to AP. The AP might want to update the dongle firmware when you first connect it. Link to comment Share on other sites More sharing options...
beanmachine Posted March 15, 2014 Author Share Posted March 15, 2014 Already did that but thanks guys. I'm fine with using cobb software and the device as I used it plenty with my ms3 just wanted to know if the year made a difference. With the speed3 we could use the same maps for the 2010-2012. I already deleted the '08 maps and loaded the '07. Gonna flash the stage 1 93 to it today and have some fun once I make sure everything is running smoothly. There was a problem with the link to download the anti theft map for the '07 though so I'm missing that one. Sent from my GT-N8013 using Tapatalk Link to comment Share on other sites More sharing options...
