discojon Posted February 9, 2014 Share Posted February 9, 2014 I recently purchased the gauge from a member here and working is working great with the exception of being able to hook my wideband to it . in all the pictures and documents there is shown several accessory wires coming out if the case, one such happens to be for AFR. My unit just has the vacuum port,power port, 2additional ports and the display connection. I assume one of the additional ports is programming and one is accessory but how do I how my sensor up to it? Link to comment Share on other sites More sharing options...
TheBlackPearl Posted February 9, 2014 Share Posted February 9, 2014 Does your wide band have an analog output wire for connecting an external guage? Self proclaimed PNW Craiglist find of the day Champion, April 2014. Link to comment Share on other sites More sharing options...
discojon Posted February 9, 2014 Author Share Posted February 9, 2014 The wideband isn't the the issue but yea it does. There are no wires on the vbg-1 to connect it too. Mine doesn't have the same configuration as the ones in the guide. Sent from my SAMSUNG-SGH-I747 using Tapatalk Link to comment Share on other sites More sharing options...
discojon Posted February 11, 2014 Author Share Posted February 11, 2014 Got this solved. The newest versions have an integrated power and analog input line. The Green line that used to be for dimming is now for analog input. Hooked the 0-5v input up and bam, like a champ. Link to comment Share on other sites More sharing options...
